thinkgeo.mapsuite.core.restrictionlayer
ThinkGeo.MapSuite.Core.RestrictionLayer
This layer can show or hide one or many zones that you want to restrict from being displayed. You can use the specified style to decorate the zones and set the lower/upper scale to control at which zoom levels you want to show or hide the zones. The default decoration style is a hatch pattern. You can change this to a circle with slash image, or, if you want a different look, you can use custom styles.
      • ThinkGeo.MapSuite.Core.RestrictionLayer
RestrictionLayer()
  • Initializes a new instance of the RestictionLayer class.
RestrictionLayer(IEnumerable<AreaBaseShape>)
  • Initializes a new instance of the RestictionLayer class for the specified zones.
RestrictionLayer(IEnumerable<AreaBaseShape>,RestrictionMode)
  • Initializes a new instance of the RestictionLayer class for the specified zones and restriction mode.
RestrictionLayer(IEnumerable<AreaBaseShape>,RestrictionMode,Double,Double)
  • Initializes a new instance of the RestictionLayer class for the specified zones, restriction mode, upper scale and lower scale.
  • upperScale
  • lowerScale
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
GetBoundingBoxCore()
  • This method returns the bounding box of the zones.
  • Description:This method returns the bounding box of the zones.
  • This method draws the Layer.
  • This abstract method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
  • labelsInAllLayers
    • Description:This parameter represents the labels used for collision detection and duplication checking.
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
OpenCore()
CloseCore()
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
UpperScale
Specifies the upper threshold of the layer.
If Restriction mode is ShowZones:If currentScale is greater than UpperScale, it will hide the whole map; otherwise, it will show the specified zones.If Restriction mode is HideZones:If currentScale is less than or equal to UpperScale and greater than or equal to LowerScale, it will hide the specified zones; otherwise, it will do nothing.
LowerScale
Specifies the lower threshold of the layer.
If Restriction mode is ShowZones:If currentScale is less than LowerScale, it will hide the whole map; otherwise, it will show the specified zones.If Restriction mode is HideZones:if currentScale is less than or equal to UpperScale and greater than or equal to LowerScale, it will hide the specified zones; otherwise it will do nothing.
CustomStyles
Allows you to add custom styles to decorate restriction zones. In this case, you must set RestrictionStyle to UseCustomStyles as well.
RestrictionMode
Specifies whether you want to show or hide zones.
Zones
Specifies the areas you want to restrict.
RequestDrawingInterval
  • Type:TimeSpan
IsOpen
HasBoundingBox
DrawingTime
  • Type:TimeSpan
Attribution
IsVisible
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
IsGrayscale
DrawingExceptionMode
IsOpenCore
RequestedDrawing N/A
RequestingDrawing N/A
DrawingProgressChanged N/A
DrawingException N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
thinkgeo.mapsuite.core.restrictionlayer.txt · Last modified: 2017/03/16 21:59 (external edit)
