SaveTiles(Bitmap,RectangleShape,Boolean)
SaveTiles(Bitmap,RectangleShape)
Gets or sets the Mode for the TileCache access the tiles. The Default value is ReadAddDelete
If you want it to take effect, you need set the ReadOnly property false.
This property returns back a preset image showing the tile data is missing.
Gets or sets the Jpeg quality , this property only take effects when setting the ImageFormat to Jpeg.
