thinkgeo.mapsuite.portablecore
ThinkGeo.MapSuite.Core
MapSuitePortableCore
Classes
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
B
  • BackgroundLayer
    This class draws the background of the map.
  • BaseShape
    The abstract class from which area shapes, line shapes, and point shapes inherit from.
  • BingMapsZoomLevelSet
    This class represents the zoom levels used by Bing Maps.
  • BitmapTile
    This class represents a NativeImageTile, which is defined as scale, RectangleBox and a byte array for its tile bitmap.
  • BitmapTileCache
  • BuildingIndexShapeFileFeatureSourceEventArgs
    This class represents the parameters passed in through the BuildingIndex event in ShapeFileFeatureSource class.
C
D
E
F
  • Feature
  • FeatureCache
  • FeatureLayer
  • FeatureSource
  • FeatureSourceColumn
  • FileBitmapTileCache
  • FileNativeImageTileCache
G
H
  • HeatLayer
  • HeatStyle
  • HueFamilyAreaStyle
I
K
L
  • LabelInformation
    This class represents the location of a piece of a label that may be drawn.
  • LabelingCandidate
    This class represents a candidate for labeling.
  • Layer
    This class is the base class for all types of Layers.
  • LayerDrawingEventArgs
  • LayerDrawnEventArgs
  • LayersDrawingEventArgs
  • LayersDrawnEventArgs
  • LegendAdornmentLayer
    Class LegendAdornmentLayer.
  • LineBaseShape
  • LineShape
  • LineStyle
    This class is the style used to draw lines.
  • LineStyles
    This class is a collection of predefined styles and helper methods to create styles.
  • LogoAdornmentLayer
    This is the sub base class of AdornmentLayer. The LogoAdornmentLayer is taken as Logo map of the Map Control.
M
  • ManagedProj4Projection
  • MapEngine
    This class is for generating maps.
  • MapShape
    This class represent a unit can be drawn on map. Each MapShape composes of a feature and a ZoomLevelSet to control its drawing zoomlevels.
  • MapShapeLayer
    Ideally I would want to make this inherit from the FeatureLayer so you could do spatial queries. In the interests of time I inherited from the Layer to make things simple and show the point of how easy it is to extend Map Suite. When we roll this into the main product we may create a FeatureSource and FeatureLayer.
  • MapSuiteTileMatrix
    This class defines the TileMatrix system used in MapSuite component.
  • Matrix
    This class represents a base Matrix which encapsulate the tile caculation logics.
  • MultilineShape
  • MultipleFeatureLayer
    This class represents a Layer backed by multiple Shape Files.
  • MultipleFeatureSource
    This MultipleFeatureSource is a special FeatureSource which holds a bunch of FeatureSource.
  • MultipleShapeFileFeatureLayer
    This layer represents multiple Shape Files of the same type.
  • MultipleShapeFileFeatureSource
    This class represents a FeatureSource backed by multiple ESRI Shape Files.
  • MultipointShape
    This class represents one or more point shapes.
  • MultipolygonShape
N
  • NativeImageTile
  • NativeImageTileCache
    This is the base class for NativeTileCache system which inherits from TileCache class.
  • NonSerializableBaseTypeAttribute
    Indicates that a type's base type should not be serialized.
O
P
Q
R
S
T
  • TextStyle
  • TextStyleAdvanced
  • TextStyles
  • Tile
    This is the base class which describe the Tile class. Tile concept is used as a rectangle image which will be saved in Memory or Hard disk to enhance the performance.The Tile cache system is very popular in many GIS products including the GoogleMaps, VE Maps etc, the Tile can be considered a small subset used in the TileCache system.
  • TileCache
  • TileMatrix
  • TileMatrixSet
  • TiledWmsLayer
  • TinyGeoFeatureLayer
  • TinyGeoFeatureSource
  • TransactionBuffer
  • TransactionResult
V
W
X
Z
  • ZoomLevel
  • ZoomLevelSet
Structures
D
G
  • GeoColor
L
R
  • RowColumnRange
S
  • ScreenPointF
  • ShapeValidationResult
T
  • TileMatrixCell
V
  • Vertex
Enums
A
B
C
D
  • DbfColumnType
    This enumeration represents the column type in the DBF.
  • DbfReadWriteMode
    Dbf read write mode
  • DistanceUnit
    Units describing various ways you can measure lengths.
  • DrawingExceptionMode
    This enum is used to describe some choice when exception hanppens during drawing Layers or Overlays.
  • DrawingFontStyles
    This enumeration specifies the type of font style for drawing text.
  • DrawingGraphicsUnit
    This enumeration represents the graphics unit.
  • DrawingLevel
    This enumeration represents the drawing level used in the GeoCanvas.
  • DrawingLineCap
  • DrawingLineJoin
    This enumeration specifies how to join consecutive line or curve segments.
  • DrawingPenAlignment
  • DrawingQuality
    This enumeration specifies the drawing quality of the GeoCanvas.
F
G
I
L
M
O
P
  • PanDirection
    This enumeration defines panning directions.
  • PenBrushDrawingOrder
    This enumeration determines whether the brush or the pen draws first.
  • PointPlacement
    This enumeration determines the label placement when labeling point features.
  • PointSymbolType
    This enumeration defines the different types of PointSymbols that can be drawn.
  • PointType
    This enumeration defines how a PointSymbol will be drawn.
  • PolygonLabelingLocationMode
    Labeling Location Mode for polygon
  • Proj4MemoryMode
    The enumeration indicates which way are specified to read the projection information.
Q
  • QueryType
R
S
T
  • TileAccessMode
  • TileImageFormat
  • TinyGeoPrecisionMode
  • TransactionResultStatus
U
W
Interfaces
thinkgeo.mapsuite.portablecore.txt · Last modified: 2017/03/16 21:59 (external edit)
