thinkgeo.mapsuite.portable.portablestring
ThinkGeo.MapSuite.Portable.PortableString
    • ThinkGeo.MapSuite.Portable.PortableString
PortableString()
Copy(String)
  • str
CopyCore(String)
  • str
ToString(String,CultureInfo)
  • sourceString
  • cultureInfo
    • Type:CultureInfo
ToStringCore(String,CultureInfo)
  • sourceString
  • cultureInfo
    • Type:CultureInfo
Contains(String,Char)
  • sourceString
  • value
    • Type:Char
ContainsCore(String,Char)
  • sourceString
  • value
    • Type:Char
thinkgeo.mapsuite.portable.portablestring.txt · Last modified: 2017/03/16 21:59 (external edit)
