thinkgeo.mapsuite.portable.portablewebclient
ThinkGeo.MapSuite.Portable.PortableWebClient
    • ThinkGeo.MapSuite.Portable.PortableWebClient
PortableWebClient()
OpenRead(Object,Uri)
  • Type:Stream
  • concrete
  • uri
    • Type:Uri
OpenReadCore(Object,Uri)
  • Type:Stream
  • concrete
  • uri
    • Type:Uri
OpenRead(Object,String)
  • Type:Stream
  • concrete
  • path
OpenReadCore(Object,String)
  • Type:Stream
  • concrete
  • path
Create()
CreateCore()
Dispose(Object)
  • concrete
DisposeCore(Object)
  • concrete
DownloadFile(Object,String,String)
  • concrete
  • address
  • fileName
DownloadFileCore(Object,String,String)
  • concrete
  • address
  • fileName
thinkgeo.mapsuite.portable.portablewebclient.txt · Last modified: 2017/03/16 21:59 (external edit)
