thinkgeo.mapsuite.portable.portableenvironment
ThinkGeo.MapSuite.Portable.PortableEnvironment
    • ThinkGeo.MapSuite.Portable.PortableEnvironment
PortableEnvironment()
GetSystemDirectory()
GetSystemDirectoryCore()
GetEnvironmentVariable(String)
  • variable
GetEnvironmentVariableCore(String)
  • variable
Exit(Int32)
  • exitCode
ExitCore(Int32)
  • exitCode
GetTemporaryFolder()
GetTemporaryFolderCore()
GetMachineName()
GetMachineNameCore()
GetCurrentDirectory()
GetCurrentDirectoryCore()
thinkgeo.mapsuite.portable.portableenvironment.txt · Last modified: 2017/03/16 21:59 (external edit)
