thinkgeo.mapsuite.portable.portablebinaryformatter
ThinkGeo.MapSuite.Portable.PortableBinaryFormatter
    • ThinkGeo.MapSuite.Portable.PortableBinaryFormatter
PortableBinaryFormatter()
Serialize(Stream,Object)
  • stream
    • Type:Stream
  • graph
SerializeCore(Stream,Object)
  • stream
    • Type:Stream
  • graph
Deserialize(Stream)
  • stream
    • Type:Stream
DeserializeCore(Stream)
  • stream
    • Type:Stream
thinkgeo.mapsuite.portable.portablebinaryformatter.txt · Last modified: 2017/03/16 21:59 (external edit)
