thinkgeo.mapsuite.portable.portabledirectory
ThinkGeo.MapSuite.Portable.PortableDirectory
    • ThinkGeo.MapSuite.Portable.PortableDirectory
PortableDirectory()
GetFiles(String,String)
  • Type:String[]
  • path
  • searchPattern
GetFilesCore(String,String)
  • Type:String[]
  • path
  • searchPattern
GetDirectories(String,String,SearchOption)
  • Type:String[]
  • path
  • searchPattern
  • searchOption
    • Type:SearchOption
GetDirectoriesCore(String,String,Int32)
  • Type:String[]
  • path
  • searchPattern
  • searchOption
GetFiles(String)
  • Type:String[]
  • path
GetFilesCore(String)
  • Type:String[]
  • path
Exists(String)
  • path
ExistsCore(String)
  • path
CreateDirectory(String)
  • directory
CreateDirectoryCore(String)
  • directory
Delete(String,Boolean)
  • path
  • recursive
DeleteCore(String,Boolean)
  • path
  • recursive
GetFiles(String,String,Int32)
  • Type:String[]
  • path
  • searchPattern
  • searchOption
GetFilesCore(String,String,Int32)
  • Type:String[]
  • path
  • searchPattern
  • searchOption
Delete(String)
  • path
DeleteCore(String)
  • path
thinkgeo.mapsuite.portable.portabledirectory.txt · Last modified: 2017/03/16 21:59 (external edit)
