thinkgeo.mapsuite.portable.portablewebresponse
ThinkGeo.MapSuite.Portable.PortableWebResponse
    • ThinkGeo.MapSuite.Portable.PortableWebResponse
PortableWebResponse()
IsFromCache(WebResponse)
  • webResponse
    • Type:WebResponse
GetResponse(WebRequest)
  • Type:WebResponse
  • request
    • Type:WebRequest
GetResponseCore(WebRequest)
  • Type:WebResponse
  • request
    • Type:WebRequest
SetTimeout(WebRequest,Int32)
  • webRequest
    • Type:WebRequest
  • timeout
SetTimeoutCore(WebRequest,Int32)
  • webRequest
    • Type:WebRequest
  • timeout
SetProxy(WebRequest,GeoWebProxy)
  • webRequest
    • Type:WebRequest
SetProxyCore(WebRequest,GeoWebProxy)
  • webRequest
    • Type:WebRequest
IsFromCacheCore(WebResponse)
  • webResponse
    • Type:WebResponse
thinkgeo.mapsuite.portable.portablewebresponse.txt · Last modified: 2017/03/16 21:59 (external edit)
