thinkgeo.mapsuite.portable.portableencoding
ThinkGeo.MapSuite.Portable.PortableEncoding
    • ThinkGeo.MapSuite.Portable.PortableEncoding
PortableEncoding()
GetDefaultEncoding()
  • Type:Encoding
GetDefaultEncodingCore()
  • Type:Encoding
GetEncoding(Int32)
  • Type:Encoding
  • codepage
GetEncodingCore(Int32)
  • Type:Encoding
  • codepage
GetCodePage(Encoding)
  • encoding
    • Type:Encoding
GetCodePageCore(Encoding)
  • encoding
    • Type:Encoding
GetString(Encoding,Byte[])
  • encoding
    • Type:Encoding
  • byteValues
    • Type:Byte[]
GetStringCore(Encoding,Byte[])
  • encoding
    • Type:Encoding
  • byteValues
    • Type:Byte[]
CreateASCIIEncoding()
CreateASCIIEncodingCore()
GetBytes(Object,String)
  • Type:Byte[]
  • concrete
  • s
GetBytesCore(Object,String)
  • Type:Byte[]
  • concrete
  • s
GetString(Object,Byte[],Int32,Int32)
  • concrete
  • characters
    • Type:Byte[]
  • index
  • count
GetStringCore(Object,Byte[],Int32,Int32)
  • concrete
  • characters
    • Type:Byte[]
  • index
  • count
GetEncoding(String)
  • Type:Encoding
  • name
GetEncodingCore(String)
  • Type:Encoding
  • name
thinkgeo.mapsuite.portable.portableencoding.txt · Last modified: 2017/03/16 21:59 (external edit)
