thinkgeo.mapsuite.portable.portablefile
ThinkGeo.MapSuite.Portable.PortableFile
    • ThinkGeo.MapSuite.Portable.PortableFile
PortableFile()
ReadAllText(String)
  • path
ReadAllTextCore(String)
  • path
Open(String,GeoFileMode,GeoFileAccess)
  • Type:Stream
  • path
OpenCore(String,GeoFileMode,GeoFileAccess)
  • Type:Stream
  • path
Open(String,GeoFileMode,GeoFileAccess,GeoFileShare)
  • Type:Stream
  • path
OpenCore(String,GeoFileMode,GeoFileAccess,GeoFileShare)
  • Type:Stream
  • path
Create(String)
  • Type:Stream
  • path
CreateCore(String)
  • Type:Stream
  • path
ReadAllBytes(String)
  • Type:Byte[]
  • path
ReadAllBytesCore(String)
  • Type:Byte[]
  • path
WriteAllLines(String,String[])
  • path
  • lines
    • Type:String[]
WriteAllLinesCore(String,String[])
  • path
  • lines
    • Type:String[]
ReadAllLines(String)
  • Type:String[]
  • path
ReadAllLinesCore(String)
  • Type:String[]
  • path
OpenRead(String)
  • Type:Stream
  • path
OpenReadCore(String)
  • Type:Stream
  • path
Exists(String)
  • path
ExistsCore(String)
  • path
Delete(String)
  • path
DeleteCore(String)
  • path
SetAttributes(String,FileAttributes)
  • path
  • fileAttributes
    • Type:FileAttributes
SetAttributesCore(String,Int32)
  • path
  • fileAttributes
Move(String,String)
  • sourceFileName
  • destFileName
MoveCore(String,String)
  • sourceFileName
  • destFileName
Copy(String,String,Boolean)
  • sourceFileName
  • destFileName
  • overwrite
CopyCore(String,String,Boolean)
  • sourceFileName
  • destFileName
  • overwrite
WriteAllBytes(String,Byte[])
  • fileName
  • bytes
    • Type:Byte[]
WriteAllBytesCore(String,Byte[])
  • fileName
  • bytes
    • Type:Byte[]
GetLastWriteTime(String)
  • Type:DateTime
  • path
GetLastWriteTimeCore(String)
  • Type:DateTime
  • path
GetAttributes(String)
  • filename
GetAttributesCore(String)
  • filename
SetCreationTime(String,DateTime)
  • filename
  • dateTime
    • Type:DateTime
SetCreationTimeCore(String,DateTime)
  • filename
  • dateTime
    • Type:DateTime
SetLastWriteTime(String,DateTime)
  • filename
  • dateTime
    • Type:DateTime
SetLastWriteTimeCore(String,DateTime)
  • filename
  • dateTime
    • Type:DateTime
thinkgeo.mapsuite.portable.portablefile.txt · Last modified: 2017/03/16 21:59 (external edit)
