thinkgeo.mapsuite.mapsuitegeocoder.censusblockgroupdbfmatchingplugin
ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin
This is the derived class of the class DbfMatchingPlugIn for matching Census Block Group areas.
    • ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin
      • ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin
        • ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin
CensusBlockGroupDbfMatchingPlugin()
  • This is the constructor of this class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#CensusBlockGroupDbfMatchingPlugin.28.29
CensusBlockGroupDbfMatchingPlugin(String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#CensusBlockGroupDbfMatchingPlugin.28String.29
  • pathFileName
    • Description:The path and file name of the DBF file to be used for Census Block Group Geocoding.
GetRecord(Int32)
  • This method gets a record by record index from the DBF file.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetRecord.28Int32.29
  • Description:The record value.
  • recordNumber
    • Description:This parameter is the record number.
GetRecords(Int32,Int32)
  • This method gets records by using the specified range.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetRecords.28Int32.2C_Int32.29
  • Type:Collection<Dictionary<String,String»
  • Description:The collection of record values.
  • firstRecordNumber
    • Description:This parameter is the first record number to get.
  • count
    • Description:This parameter is the record count to return.
AddRecord(IEnumerable<Object>)
  • This method adds one record to the DBF file.
  • values
    • Type:IEnumerable<Object>
    • Description:This parameter represents a record in the DBF file.
Dispose()
  • Releases all resources used by the DbfMatchingPlugin.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Dispose.28.29
Match(String)
  • This method matches the source text and returns a collection of GeocoderMatch. This method is the concrete wrapper for MatchCore. It firstly formalizes the input sourceText, gets the formalized results and matches them using MatchCore one by one, then returns all of the results within a collection.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Match.28String.29
  • Type:Collection<GeocoderMatch>
  • Description:A collection of GeocoderMatch.
  • sourceText
    • Description:The source text to match.
Open()
  • This method opens the MatchingPlugin for use. This method is the concrete wrapper for OpenCore.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Open.28.29
Close()
  • This method closes the MatchingPlugin. This method is the concrete wrapper for CloseCore.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Close.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetType.28.29
FormalizeCore(String)
  • This method formalizes source text to get possible census blocks.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#FormalizeCore.28String.29
  • Type:Collection<String>
  • Description:The collection containing possible census blocks.
  • sourceText
    • Description:The source text to formalize.
MatchCore(String)
  • This method matches the source text and returns a result with a collection of GeocoderMatch.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#MatchCore.28String.29
  • sourceText
OpenCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#OpenCore.28.29
CloseCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#CloseCore.28.29
SearchUpperBound(Int32,Int32,String,String)
  • This method gets the record number of the upper boundary of the matched results.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#SearchUpperBound.28Int32.2C_Int32.2C_String.2C_String.29
  • Description:The record number of the upper boundary of the matched results.
  • firstRecordNumber
    • Description:The first record number for the search.
  • lastRecordNumber
    • Description:The last record number for the search.
  • sourceText
    • Description:The source text to search for.
  • columnName
    • Description:The name of the column on which the search is based.
SearchLowerBound(Int32,Int32,String,String)
  • This method gets the record number of the lower boundary of the matched results.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#SearchLowerBound.28Int32.2C_Int32.2C_String.2C_String.29
  • Description:The record number of the lower boundary of the matched results.
  • firstRecordNumber
  • lastRecordNumber
  • sourceText
  • columnName
GetKeyColumnName()
  • This method gets the key column name from the DBF file.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#GetKeyColumnName.28.29
  • Description:The key column name.
BinarySearch(Int32,Int32,String,String)
  • This method does a binary search on the DBF file and returns the record it hits.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#BinarySearch.28Int32.2C_Int32.2C_String.2C_String.29
  • Description:The record hits in the search.
  • firstRecordNumber
  • lastRecordNumber
  • sourceText
  • columnName
    • Description:The name of the column on which the binaray search is based.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Finalize.28.29
Formalize(String)
  • This method formalizes the source text. This method is the concrete wrapper of FormalizeCore.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#Formalize.28String.29
  • Description:The collection of formalized strings.
  • sourceText
oxM=(GeocoderMatch)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.CensusBlockGroupDbfMatchingPlugin#MemberwiseClone.28.29
PathFileName
Gets and sets the path and file name of the DBF file to be used for Geocoding.
ReadWriteMode
The read/write mode for the DBF file.
RecordCount
This record count of the DBF file.
RankingMultiplier
This property is the ranking multipier for GeocoderMatch.
thinkgeo.mapsuite.mapsuitegeocoder.censusblockgroupdbfmatchingplugin.txt · Last modified: 2017/03/16 21:59 (external edit)
