thinkgeo.mapsuite.portable.portablestopwatch
ThinkGeo.MapSuite.Portable.PortableStopwatch
    • ThinkGeo.MapSuite.Portable.PortableStopwatch
PortableStopwatch()
Create()
CreateCore()
Start(Object)
  • concrete
StartCore(Object)
  • concrete
Stop(Object)
  • concrete
StopCore(Object)
  • concrete
GetElapsedMilliseconds(Object)
  • Type:Int64
  • concrete
GetElapsedMillisecondsCore(Object)
  • Type:Int64
  • concrete
GetElapsed(Object)
  • Type:TimeSpan
  • concrete
GetElapsedCore(Object)
  • Type:TimeSpan
  • concrete
Reset(Object)
  • concrete
ResetCore(Object)
  • concrete
thinkgeo.mapsuite.portable.portablestopwatch.txt · Last modified: 2017/03/16 21:59 (external edit)
