thinkgeo.mapsuite.portable.portableconsole
ThinkGeo.MapSuite.Portable.PortableConsole
    • ThinkGeo.MapSuite.Portable.PortableConsole
PortableConsole()
GetError()
  • Type:TextWriter
GetErrorCore()
  • Type:TextWriter
OpenStandardError()
  • Type:Stream
OpenStandardErrorCore()
  • Type:Stream
OpenStandardOutput()
  • Type:Stream
OpenStandardOutputCore()
  • Type:Stream
WriteLine()
WriteLine(String)
  • message
WriteLineCore(String)
  • message
thinkgeo.mapsuite.portable.portableconsole.txt · Last modified: 2017/03/16 21:59 (external edit)
