<!– NamespacePage –> <!– GisEditorInfrastructure –>
| Name | Summary |
| AdvancedQueryUserControl | Interaction logic for AdvancedQueryUserControl.xaml |
| AutoBackupIntervalChangedProjectPluginManagerEventArgs | |
| BuildingRibbonBarUIPluginManagerEventArgs | |
| BuiltRibbonBarUIPluginManagerEventArgs | |
| CanAutoBackupChangedProjectPluginManagerEventArgs | |
| CommonProjection | Interaction logic for CommonProjection.xaml |
| ControlPlugin | This class represents a control plugin |
| ControlPluginManager | |
| DataRepositoryItem | This class represents a data repository item. |
| DataRepositoryPlugin | This plugin is the base class of all data repository plugins. GisEditor collects those plugins to create the data repository tree. |
| DataRepositoryPluginManager | This class represents a data repository manager. |
| DataViewerHelper | |
| DataViewerUserControl | Interaction logic for DbfViewerUserControl.xaml |
| DockWindow | This class is wrapper for the actual dock control used in the application. |
| DockWindowManager | This class represents a dock window manager. |
| DockWindowOpenedDockWindowManagerEventArgs | |
| DocumentWindow | |
| ExceptionInfo | |
| Exporter | |
| FeatureLayerPlugin | |
| FeatureLayerPropertiesUserControl | Interaction logic for MetadataUserControl.xaml |
| FileExportInfo | |
| FileExporter | |
| GetLayerListItemContextMenuParameters | This class represents contex menu arguments for layer list item |
| GetLayersParameters | |
| GetMapContextMenuParameters | This class represents an arguement to create the context menu items on the map. It will be used by the UIPlugin.GetMapContextMenuItems(MapContextMenuArguments); |
| GettingLayerListItemContextMenuItemsEventArgs | |
| GettingLayersLayerPluginEventArgs | |
| GisEditor | This class contains some global objects will be accessed by both shell and plugins. |
| GottenLayerListItemContextMenuItemsEventArgs | |
| GottenLayersLayerPluginEventArgs | |
| GottenMapContextMenuItemsUIPluginManagerEventArgs | |
| InfrastructureManager | Manager of all options in explorer, including options of plugins, infrastructures and shell. |
| LanguageInfo | |
| LanguageManager | |
| LayerListItem | |
| LayerListManager | |
| LayerPlugin | This class is the base class of all LayerPlugins. This plugin provides the functionality of creating a specific type of layer instance. |
| LayerPluginManager | |
| LoadingPreviewImageProjectPluginManagerEventArgs | |
| LoggedLoggerManagerEventArgs | |
| LoggerMessage | |
| LoggerPlugin | This class represent a plugin for a logger |
| LoggerPluginManager | This is the manager of logging system. |
| LoggingLoggerManagerEventArgs | |
| Manager | This class represents a base class of Managers in all GISEditor system. |
| ObjectPropertiesUserControl | Interaction logic for ObjectPropertiesUserControl.xaml |
| OpenedProjectManagerEventArgs | |
| OpeningProjectManagerEventArgs | |
| OtherProjection | Interaction logic for OtherProjection.xaml |
| OutputWindow | |
| Plugin | This class represents a base class of Plugins in all GISEditor system. |
| PluginManager | This class represents a base class of PluginManagers in all GISEditor system. |
| PluginManagerWindow | Interaction logic for PluginConfigurationWindow.xaml |
| ProjectPlugin | This class represents a plugin for project. |
| ProjectPluginManager | |
| ProjectSaveAsResult | This class represents a project which can be saved as a result |
| ProjectStreamInfo | |
| ProjectionSelectionViewModel | |
| ProjectionSelectionWindow | Interaction logic for MainWindow.xaml |
| QueryConditionViewModel | |
| QueryConditionWindow | Interaction logic for QueryBuilder.xaml |
| QueryFeatureWindow | |
| QueryOperater | |
| RefreshArgs | |
| RefreshedPluginsUIPluginManagerEventArgs | |
| RibbonEntry | |
| SelectedLayerListItemChangedLayerListManagerEventArgs | |
| SelectionManager | |
| SettingUserControl | This class represents an user control for a setting |
| ShapeFileExporter | |
| SimpleQueryUserControl | Interaction logic for QuickFindUserControl.xaml |
| SimpleQueryViewModel | |
| StorableSettings | This class represents storable settings |
| StyleBuilderArguments | This class represents a style builder arguments |
| StyleBuilderResult | This class represents a style builder result |
| StyleBuilderWindow | Interaction logic for StyleConfigurationWindow.xaml |
| StyleLayerListItem | This class represents a list item for a style layer |
| StyleLibraryWindow | Interaction logic for StyleLibraryWindow.xaml |
| StylePlugin | This class represents style plugin |
| StylePluginManager | |
| StyleUserControl | This class represents an user control with specified style |
| StyleWizardResult | |
| StyleWizardWindow | |
| TaskPlugin | |
| TaskPluginManager | |
| ThemeChangedDockWindowManagerEventArgs | |
| UIPlugin | This is an abstract class. Also this is a base class which will be used for creating our own plugins |
| UIPluginManager | |
| UpdateChannel | |
| UpdateManager | |
| UpdatingTaskProgressEventArgs | |
| UriChangedProjectPluginManagerEventArgs |
| Name | Summary |
| Name | Summary |
| DbfViewerDockingMode | |
| DbfViewerEditMode | |
| DbfViewerShowSelectedFeaturesMode | |
| DockWindowPosition | Specifies the side of the main window that a dock control will be shown on. |
| DockWindowStartupMode | This enumeration represents where to place a dock window at startup. |
| LoggerLevel | Default value is Off. |
| MovementAction | |
| OutputMode | |
| QueryMatchMode | |
| QueryOperaterType | |
| SimpleShapeType | |
| StyleBuilderUIElements | This enum represents a style builder UI elements |
| StyleCategories | This enum represents a style categories |
| TaskCommand | |
| TaskState | |
| Theme | This enum represents the theme options |
| UpdateMode |
| Name | Summary |
| IStorableSettings | |
| ITaskCallbackReceiver | |
| ITaskHost |
<!– GisEditorInfrastructure –> Note: * – not public released, might be removed in the next release. GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
