<!– Class –> This class is wrapper for the actual dock control used in the application.
*System.Object **ThinkGeo.MapSuite.GisEditor.DockWindow
DockWindow | Initializes a new instance of the DockablePanel class. | ||
DockWindow | Control | Initializes a new instance of the class. | |
DockWindow | Control, DockWindowPosition | Initializes a new instance of the class. | |
DockWindow | Control, DockWindowPosition, String | Initializes a new instance of the class. |
Show | DockWindowPosition | Shows a popup dock window. | |
Show | Shows a popup dock window as floating window. | ||
MemberwiseClone | Object | ||
ShowCore | DockWindowPosition | Shows the core. |
Content | Control | Gets or sets the content of DockablePanel. | |
FloatingLocation | WindowStartupLocation | Gets or sets the position of the window when first shown. | |
FloatingSize | Size | Gets or sets the floating size of the dock control. | |
Name | String | Gets or sets the name. | |
Position | DockWindowPosition | Gets or sets which side of the main window should the dock control be. | |
StartupMode | DockWindowStartupMode | Gets or sets the startup mode of DockablePanel. | |
Title | String | Gets or sets a DockablePanel's title. |
| content | Control<!– System.Windows.Controls.Control –> | The content. |
| dockPlacement | DockWindowPosition<!– ThinkGeo.MapSuite.GisEditor.DockWindowPosition –> | The dock placement. |
| position | DockWindowPosition<!– ThinkGeo.MapSuite.GisEditor.DockWindowPosition –> | The position. |
| title | String<!– System.String –> | The title. |
| dockWindowPosition | DockWindowPosition<!– ThinkGeo.MapSuite.GisEditor.DockWindowPosition –> | Indicates where the dock window should be shown. |
<!– ThinkGeo.MapSuite.GisEditor.DockWindow –> Go Back
Shows the core.
| dockWindowPosition | DockWindowPosition<!– ThinkGeo.MapSuite.GisEditor.DockWindowPosition –> | The dock window position. |
| WindowStartupLocation<!– System.Windows.WindowStartupLocation –> |
| Size<!– System.Windows.Size –> |
| DockWindowStartupMode<!– ThinkGeo.MapSuite.GisEditor.DockWindowStartupMode –> |
