<!– Class –> This class represents an arguement to create the context menu items on the map. It will be used by the UIPlugin.GetMapContextMenuItems(MapContextMenuArguments);
*System.Object **ThinkGeo.MapSuite.GisEditor.GetMapContextMenuParameters
GetMapContextMenuParameters | Initializes a new instance of the class. | ||
GetMapContextMenuParameters | PointShape, PointShape, Double, Double | Initializes a new instance of the class. |
GetClickWorldArea | |||
GetClickWorldArea | Int32 | ||
CurrentResolution | Double | ||
CurrentScale | Double | ||
ScreenCoordinates | PointShape | Gets or sets the screen coordinates. | |
WorldCoordinates | PointShape | Gets or sets the world coordinates. |
| screenCoordinates | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | The screen coordinates. |
| worldCoordinates | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | The world coordinates. |
| currentScale | Double<!– System.Double –> | |
| currentResolution | Double<!– System.Double –> |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
<!– ThinkGeo.MapSuite.GisEditor.GetMapContextMenuParameters –> Go Back
| tolerance | Int32<!– System.Int32 –> |
