<!– Class –>
*System.Object System.EventArgs *ThinkGeo.MapSuite.GisEditor.CanAutoBackupChangedProjectPluginManagerEventArgs
CanAutoBackupChangedProjectPluginManagerEventArgs | Initializes a new instance of the class. | ||
CanAutoBackupChangedProjectPluginManagerEventArgs | Boolean | Initializes a new instance of the class. |
CanAutoBackup | Boolean | Gets or sets a value indicating whether this instance can auto backup. |
| canAutoBackup | Boolean<!– System.Boolean –> | if set to true auto backup. |
<!– ThinkGeo.MapSuite.GisEditor.CanAutoBackupChangedProjectPluginManagerEventArgs –> Go Back
