map_suite_wpf_desktop_edition_background_maps_google_bing_etc_samples
Map Suite Wpf Desktop Edition Background Maps (Google, Bing, etc) Samples
GPS to Google Map(Desktop)
Today we have the Desktop version of the Web project “GPS to Google”. In this project, we show how to display on Google Map point data coming from some GPS reading in Geodetic (Longitude/Latitude). It also shows how to set the extent of the map so that it is centered on the GPS point.
Great Circle with Google Map
Mini map with Google Map
OpenStreetMap
ArcGISServerRestLayer
In this wpf-based project, we'll demonstrate the new ArcGISServerRestLayer released with Map Suite 9.0. This layer gives developers a simple and powerful tool to access their maps that reside on ArcGIS Server. This new layer utilizes the ArcGIS Server REST API. Now, the latest version of Map Suite Core can support that. In order to run this project, you will need the Development Build 9.0.443.0 or later.
Shapefile to Google Map
Get Features From ArcGISServer
In this wpf-based project, it illustrates how to get the features from the ArcGIS Restful Server. On the left side of the screenshot shows the raster data from ArcGIS Server and on the other side shows the features from ArcGIS Restful Server. In order to run this project, you will need the Development Build 9.0.482.0 or later.
map_suite_wpf_desktop_edition_background_maps_google_bing_etc_samples.txt · Last modified: 2017/03/17 02:12 by tgwikiupdate
