thinkgeo.mapsuite.giseditor.loggerpluginmanager
ThinkGeo.MapSuite.GisEditor.LoggerPluginManager
<!– Class –> This is the manager of logging system.
Public MethodLoggerPluginManager Initialize an instance of LoggerManager.
Public MethodApplySettings StorableSettings Manager Applies the settings to this manager.
Public MethodGetActiveLoggerPlugins Gets the logger plugins.
Public MethodGetLoggerMessages DateTime, DateTime Gets the logger messages.
Public MethodGetLoggerMessages Gets the logger messages.
Public MethodGetLoggerPlugins Gets the logger plugins.
Public MethodGetPlugins PluginManager Gets the related plugins.
Public MethodGetSettings Manager Gets manager settings to save.
Public MethodGetSettingsUI Manager Gets an UI that configures settings.
Public MethodGetType Object
Public MethodLog LoggerLevel, String, ExceptionInfo Logs the specified logger level.
Public MethodLog LoggerLevel, String, Exception Logs the specified logger level.
Public MethodLog LoggerLevel, String Logs the specified logger level.
Public MethodLog LoggerMessage Logs the specified logger message.
Public MethodToString Object
Protected MethodApplySettingsCore StorableSettings Manager Applies the settings to this manager.
Protected MethodGetLoggerMessagesCore DateTime, DateTime Gets the logger messages core.
Protected MethodGetPluginsCore PluginManager(overriden) Gets the plugins core.
Protected MethodGetSettingsCore Manager Gets manager settings to save.
Protected MethodGetSettingsUICore Manager Gets an UI that configures settings.
Protected MethodLogCore LoggerMessage Logs the core.
Protected MethodOnLogged LoggedLoggerManagerEventArgs Raises the event.
Protected MethodOnLogging LoggingLoggerManagerEventArgs Raises the event.
Public EventLogged LoggedLoggerManagerEventArgs Occurs when logged.
Public EventLogging LoggingLoggerManagerEventArgs Occurs when logging.
LoggerPluginManager()
Name Type Description
Go Back
ApplySettings(StorableSettings)
Return Type Description
Void<!– System.Void –>
settings StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> The settings to be applied to this manager.
<!– ThinkGeo.MapSuite.GisEditor.Manager –> Go Back
Boolean<!– System.Boolean –>
GetActiveLoggerPlugins()
Collection<T><!– Collection{T} –>
<!– ThinkGeo.MapSuite.GisEditor.LoggerPluginManager –> Go Back
Collection<LoggerPlugin><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.LoggerPlugin} –>
Int32<!– System.Int32 –>
GetLoggerMessages(DateTime, DateTime)
Collection<LoggerMessage><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.LoggerMessage} –>
from DateTime<!– System.DateTime –> From.
to DateTime<!– System.DateTime –> To.
GetLoggerMessages()
GetLoggerPlugins()
GetPlugins()
Collection<Plugin><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.Plugin} –>
<!– ThinkGeo.MapSuite.GisEditor.PluginManager –> Go Back
GetSettings()
StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> Manager's settings to save
GetSettingsUI()
SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> A SettingUserControl that configures settings.
Type<!– System.Type –>
Log(LoggerLevel, String, ExceptionInfo)
loggerLevel LoggerLevel<!– ThinkGeo.MapSuite.GisEditor.LoggerLevel –> The logger level.
message String<!– System.String –> The message.
error ExceptionInfo<!– ThinkGeo.MapSuite.GisEditor.ExceptionInfo –> The error.
Log(LoggerLevel, String, Exception)
error Exception<!– System.Exception –> The error.
Log(LoggerLevel, String)
Log(LoggerMessage)
loggerMessage LoggerMessage<!– ThinkGeo.MapSuite.GisEditor.LoggerMessage –> The logger message.
ApplySettingsCore(StorableSettings)
GetLoggerMessagesCore(DateTime, DateTime)
GetPluginsCore()
<!– ThinkGeo.MapSuite.GisEditor.PluginManager(overriden) –> Go Back
GetSettingsCore()
GetSettingsUICore()
LogCore(LoggerMessage)
Logs the core.
OnLogged(LoggedLoggerManagerEventArgs)
Raises the event.
e LoggedLoggerManagerEventArgs<!– ThinkGeo.MapSuite.GisEditor.LoggedLoggerManagerEventArgs –> The instance containing the event data.
OnLogging(LoggingLoggerManagerEventArgs)
Raises the event.
e LoggingLoggerManagerEventArgs<!– ThinkGeo.MapSuite.GisEditor.LoggingLoggerManagerEventArgs –> The instance containing the event data.
Logged
Occurs when logged.
Event Arguments
Event Arguments
Logging
Event Arguments
Event Arguments
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
thinkgeo.mapsuite.giseditor.loggerpluginmanager.txt · Last modified: 2017/03/16 21:59 (external edit)
