thinkgeo.mapsuite.giseditor.exceptioninfo
ThinkGeo.MapSuite.GisEditor.ExceptionInfo
<!– Class –>
Public MethodExceptionInfo Initializes a new instance of the class.
Public MethodExceptionInfo Exception
Public MethodExceptionInfo String, String, String Initializes a new instance of the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyMessage String Gets or sets the message.
Public PropertySource String Gets or sets the source.
Public PropertyStackTrace String Gets or sets the stack trace.
ExceptionInfo()
Name Type Description
Go Back
ExceptionInfo(Exception)
exception Exception<!– System.Exception –>
Go Back
ExceptionInfo(String, String, String)
message String<!– System.String –> The message.
stackTrace String<!– System.String –> The stack trace.
source String<!– System.String –> The source.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Void<!– System.Void –>
Message
Return Type
<!– ThinkGeo.MapSuite.GisEditor.ExceptionInfo –> Go Back
Source
Return Type
StackTrace
Return Type
thinkgeo.mapsuite.giseditor.exceptioninfo.txt · Last modified: 2017/03/16 21:59 (external edit)
