<!– Class –> Represents an object that encapsulates a Yahoo Map layer.
This class uses Yahoo Static Maps API to implement url request.
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.YahooMapsLayer
YahooMapsLayer | This is the constructor the for the class. If you use this constructor, then you need to set the required properties manually. | ||
YahooMapsLayer | String | This is the constructor the for the class. | |
YahooMapsLayer | String, WebProxy |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Dispose | |||
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
CloseCore | Layer(overriden) | This method closes the Layer and releases any resources it was using. | |
Dispose | Boolean | ||
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the Layer. |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer | This method returns the bounding box of the Layer. | |
MemberwiseClone | Object | ||
OpenCore | Layer(overriden) | This method opens the Layer so that it is initialized and ready to use. |
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
LicenseKey | String | Gets or sets a value represents the license key for YahooMaps API. | |
PictureFormat | YahooMapsPictureFormat | Gets or sets a value represents the image format of the image. | |
WebProxy | WebProxy | This property gets or sets the proxy used for requesting a Web Response. |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
This constructor initializes a new layer and assgin a license key.
| licenseKey | String<!– System.String –> | license key of the Yahoo Static Maps API. |
| licenseKey | String<!– System.String –> | |
| webProxy | WebProxy<!– System.Net.WebProxy –> |
<!– ThinkGeo.MapSuite.Core.YahooMapsLayer –> Go Back
| disposing | Boolean<!– System.Boolean –> |
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
| TimeSpan<!– System.TimeSpan –> |
The default value is false.
The Yahoo Maps API lets you embed Yahoo Maps in your own application. A single Maps API key is valid for a single “directory” or domain. If the license type is premier, it repesents client id, eg “gme-yourclientid”.
| YahooMapsPictureFormat<!– ThinkGeo.MapSuite.Core.YahooMapsPictureFormat –> |
| Event Arguments |
