thinkgeo.mapsuite.giseditor.manager
ThinkGeo.MapSuite.GisEditor.Manager
<!– Class –> This class represents a base class of Managers in all GISEditor system.
Protected MethodManager Initializes a new instance of the class.
Public MethodApplySettings StorableSettings Applies the settings to this manager.
Public MethodGetSettings Gets manager settings to save.
Public MethodGetSettingsUI Gets an UI that configures settings.
Public MethodGetType Object
Public MethodToString Object
Protected MethodApplySettingsCore StorableSettings Applies the settings to this manager.
Protected MethodGetSettingsCore Gets manager settings to save.
Protected MethodGetSettingsUICore Gets an UI that configures settings.
Manager()
Name Type Description
Go Back
ApplySettings(StorableSettings)
Return Type Description
Void<!– System.Void –>
settings StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> The settings to be applied to this manager.
<!– ThinkGeo.MapSuite.GisEditor.Manager –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetSettings()
StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> Manager's settings to save
GetSettingsUI()
SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> A SettingUserControl that configures settings.
Type<!– System.Type –>
String<!– System.String –>
ApplySettingsCore(StorableSettings)
GetSettingsCore()
GetSettingsUICore()
thinkgeo.mapsuite.giseditor.manager.txt · Last modified: 2017/03/16 21:59 (external edit)
