<!– Class –>
*System.Object ThinkGeo.MapSuite.GisEditor.Manager *ThinkGeo.MapSuite.GisEditor.PluginManager ThinkGeo.MapSuite.GisEditor.StylePluginManager
StylePluginManager | Initializes a new instance of the class. |
ApplySettings | StorableSettings | Manager | Applies the settings to this manager. |
EditStyle | StyleBuilderArguments | Edits the style. | |
GetActiveStylePlugins | Gets the style plugins. | ||
GetDefaultStylePlugin | StyleCategories | Gets the default style plugin. | |
GetPlugins | PluginManager | Gets the related plugins. | |
GetSettings | Manager | Gets manager settings to save. | |
GetSettingsUI | Manager | Gets an UI that configures settings. | |
GetStyleLayerListItem | Style | Gets the style layer list item. | |
GetStylePluginByStyle | Style | Gets the style plugin by style. | |
GetStylePlugins | StyleCategories | Gets the style plugins. | |
GetStylePlugins | Gets the style plugins. | ||
SaveStyleToLibrary | CompositeStyle, Double, Double | Saves the style to library. | |
ApplySettingsCore | StorableSettings | Manager(overriden) | Applies the settings core. |
EditStyleCore | StyleBuilderArguments | Edits the style core. | |
GetDefaultStylePluginCore | StyleCategories | Gets the default style plugin core. | |
GetPluginsCore | PluginManager(overriden) | Gets the plugins core. | |
GetSettingsCore | Manager(overriden) | Gets the settings core. | |
GetSettingsUICore | Manager | Gets an UI that configures settings. | |
GetStyleLayerListItemCore | Style | Gets the style layer list item core. | |
GetStylePluginByStyleCore | Style | Gets the style plugin by style core. | |
GetStylePluginsCore | StyleCategories | Gets the style plugins core. | |
MemberwiseClone | Object | ||
SaveStyleToLibraryCore | CompositeStyle, Double, Double | Saves the style to library core. |
| settings | StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | The settings to be applied to this manager. |
<!– ThinkGeo.MapSuite.GisEditor.Manager –> Go Back
Edits the style.
| StyleBuilderResult<!– ThinkGeo.MapSuite.GisEditor.StyleBuilderResult –> |
| styleBuilderArguments | StyleBuilderArguments<!– ThinkGeo.MapSuite.GisEditor.StyleBuilderArguments –> | The style builder arguments. |
<!– ThinkGeo.MapSuite.GisEditor.StylePluginManager –> Go Back
| Collection<T><!– Collection{T} –> |
| Collection<StylePlugin><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.StylePlugin} –> |
| StylePlugin<!– ThinkGeo.MapSuite.GisEditor.StylePlugin –> |
| styleProviderTypes | StyleCategories<!– ThinkGeo.MapSuite.GisEditor.StyleCategories –> | The style provider types. |
| Collection<Plugin><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.Plugin} –> |
<!– ThinkGeo.MapSuite.GisEditor.PluginManager –> Go Back
| StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | Manager's settings to save |
| SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> | A SettingUserControl that configures settings. |
| StyleLayerListItem<!– ThinkGeo.MapSuite.GisEditor.StyleLayerListItem –> |
| style | Style<!– ThinkGeo.MapSuite.Core.Style –> | The style. |
| styleCategories | StyleCategories<!– ThinkGeo.MapSuite.GisEditor.StyleCategories –> | The style categories. |
| compositeStyle | CompositeStyle<!– ThinkGeo.MapSuite.WpfDesktopEdition.Extension.CompositeStyle –> | The composite style. |
| lowerScale | Double<!– System.Double –> | The lower scale. |
| upperScale | Double<!– System.Double –> | The upper scale. |
| settings | StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | The settings. |
<!– ThinkGeo.MapSuite.GisEditor.Manager(overriden) –> Go Back
<!– ThinkGeo.MapSuite.GisEditor.PluginManager(overriden) –> Go Back
Gets or sets a value indicating whether wizard.
