<!– Class –> This class represents a style builder result
*System.Object **ThinkGeo.MapSuite.GisEditor.StyleBuilderResult
StyleBuilderResult | Initializes a new instance of the class. | ||
StyleBuilderResult | CompositeStyle | Initializes a new instance of the class. | |
StyleBuilderResult | CompositeStyle, Boolean | Initializes a new instance of the class. | |
StyleBuilderResult | CompositeStyle, Boolean, Int32, Int32 | Initializes a new instance of the class. |
Canceled | Boolean | Gets or sets a value indicating whether this is canceled. | |
CompositeStyle | CompositeStyle | Gets or sets the composite style. | |
FromZoomLevelIndex | Int32 | starts from 1. | |
ToZoomLevelIndex | Int32 | starts from 1. |
| compositeStyle | CompositeStyle<!– ThinkGeo.MapSuite.WpfDesktopEdition.Extension.CompositeStyle –> | The composite style. |
| canceled | Boolean<!– System.Boolean –> | if set to true canceled. |
| fromZoomLevelIndex | Int32<!– System.Int32 –> | Index of from zoom level. |
| toZoomLevelIndex | Int32<!– System.Int32 –> | Index of to zoom level. |
<!– ThinkGeo.MapSuite.GisEditor.StyleBuilderResult –> Go Back
starts from 1.
starts from 1.
