thinkgeo.mapsuite.giseditor.pluginmanager
ThinkGeo.MapSuite.GisEditor.PluginManager
<!– Class –> This class represents a base class of PluginManagers in all GISEditor system.
Protected MethodPluginManager Initializes a new instance of the class.
Public MethodApplySettings StorableSettings Manager Applies the settings to this manager.
Public MethodGetPlugins Gets the related plugins.
Public MethodGetSettings Manager Gets manager settings to save.
Public MethodGetSettingsUI Manager Gets an UI that configures settings.
Public MethodGetType Object
Public MethodToString Object
Protected MethodApplySettingsCore StorableSettings Manager Applies the settings to this manager.
Protected MethodGetPluginsCore Gets the related plugins.
Protected MethodGetSettingsCore Manager Gets manager settings to save.
Protected MethodGetSettingsUICore Manager Gets an UI that configures settings.
PluginManager()
Name Type Description
Go Back
ApplySettings(StorableSettings)
Return Type Description
Void<!– System.Void –>
settings StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> The settings to be applied to this manager.
<!– ThinkGeo.MapSuite.GisEditor.Manager –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetPlugins()
Collection<Plugin><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.Plugin} –>
<!– ThinkGeo.MapSuite.GisEditor.PluginManager –> Go Back
GetSettings()
StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> Manager's settings to save
GetSettingsUI()
SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> A SettingUserControl that configures settings.
Type<!– System.Type –>
String<!– System.String –>
ApplySettingsCore(StorableSettings)
GetPluginsCore()
GetSettingsCore()
GetSettingsUICore()
thinkgeo.mapsuite.giseditor.pluginmanager.txt · Last modified: 2017/03/16 21:59 (external edit)
