<!– Class –>
*System.Object ThinkGeo.MapSuite.GisEditor.Manager *ThinkGeo.MapSuite.GisEditor.PluginManager ThinkGeo.MapSuite.GisEditor.ProjectPluginManager
ProjectPluginManager | Initializes a new instance of the class. |
ApplySettings | StorableSettings | Manager | Applies the settings to this manager. |
CloseProject | Closes the project. | ||
GetActiveProjectPlugins | Gets the project plugins. | ||
GetDeserializedMaps | Gets the deserialized maps. | ||
GetPlugins | PluginManager | Gets the related plugins. | |
GetProjectPlugins | Gets the project plugins. | ||
GetSettings | Manager | Gets manager settings to save. | |
GetSettingsUI | Manager | Gets an UI that configures settings. | |
OpenProject | Opens the project. | ||
OpenProject | Uri | Opens the project. | |
OpenProject | ProjectStreamInfo | Opens the project. | |
ProjectExists | Uri | Projects the exists. | |
SaveProject | ProjectStreamInfo | Saves the project. | |
SaveProject | Uri | Saves the project. | |
SaveProject | Saves the project. | ||
AutoBackupInterval | TimeSpan | Gets or sets the auto backup interval. | |
CanAutoBackup | Boolean | Gets or sets a value indicating whether this instance can auto backup. | |
CurrentProjectPlugin | ProjectPlugin | Gets or sets the current project plugin. | |
Id | String | ||
IsLoaded | Boolean | Gets or sets a value indicating whether this instance is loaded. | |
ProjectUri | Uri | Gets or sets the project URI. |
AutoBackupIntervalChanged | AutoBackupIntervalChangedProjectPluginManagerEventArgs | Occurs when backup interval changed. | |
CanAutoBackupChanged | CanAutoBackupChangedProjectPluginManagerEventArgs | Occurs when auto backup changed. | |
Closed | EventArgs | Occurs when closed. | |
Closing | EventArgs | Occurs when closing. | |
LoadingPreviewImage | LoadingPreviewImageProjectPluginManagerEventArgs | Occurs when preview image. | |
Opened | OpenedProjectManagerEventArgs | Occurs when opened. | |
Opening | OpeningProjectManagerEventArgs | Occurs when opening. | |
ProjectUriChanged | UriChangedProjectPluginManagerEventArgs | Occurs when URI changed. |
| settings | StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | The settings to be applied to this manager. |
<!– ThinkGeo.MapSuite.GisEditor.Manager –> Go Back
Closes the project.
<!– ThinkGeo.MapSuite.GisEditor.ProjectPluginManager –> Go Back
| Collection<T><!– Collection{T} –> |
| Collection<ProjectPlugin><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.ProjectPlugin} –> |
| Collection<GisEditorWpfMap><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WpfDesktopEdition.Extension.GisEditorWpfMap} –> |
| Collection<Plugin><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.Plugin} –> |
<!– ThinkGeo.MapSuite.GisEditor.PluginManager –> Go Back
| StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | Manager's settings to save |
| SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> | A SettingUserControl that configures settings. |
Opens the project.
Opens the project.
| projectUri | Uri<!– System.Uri –> | The project URI. |
Opens the project.
| projectStreamInfo | ProjectStreamInfo<!– ThinkGeo.MapSuite.GisEditor.ProjectStreamInfo –> | The project stream info. |
Saves the project.
Saves the project.
Saves the project.
Applies the settings core.
| settings | StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | The settings. |
<!– ThinkGeo.MapSuite.GisEditor.Manager(overriden) –> Go Back
Closes the project core.
Gets the deserialized maps core.
Gets the plugins core.
<!– ThinkGeo.MapSuite.GisEditor.PluginManager(overriden) –> Go Back
Gets the settings core.
Raises the event.
| e | AutoBackupIntervalChangedProjectPluginManagerEventArgs<!– ThinkGeo.MapSuite.GisEditor.AutoBackupIntervalChangedProjectPluginManagerEventArgs –> | The instance containing the event data. |
Raises the event.
| e | CanAutoBackupChangedProjectPluginManagerEventArgs<!– ThinkGeo.MapSuite.GisEditor.CanAutoBackupChangedProjectPluginManagerEventArgs –> | The instance containing the event data. |
Raises the event.
| e | EventArgs<!– System.EventArgs –> | The instance containing the event data. |
Raises the event.
Raises the event.
| e | LoadingPreviewImageProjectPluginManagerEventArgs<!– ThinkGeo.MapSuite.GisEditor.LoadingPreviewImageProjectPluginManagerEventArgs –> | The instance containing the event data. |
Raises the event.
| e | OpenedProjectManagerEventArgs<!– ThinkGeo.MapSuite.GisEditor.OpenedProjectManagerEventArgs –> | The instance containing the event data. |
Raises the event.
| e | OpeningProjectManagerEventArgs<!– ThinkGeo.MapSuite.GisEditor.OpeningProjectManagerEventArgs –> | The instance containing the event data. |
Raises the event.
| e | UriChangedProjectPluginManagerEventArgs<!– ThinkGeo.MapSuite.GisEditor.UriChangedProjectPluginManagerEventArgs –> | The instance containing the event data. |
Opens the project core.
Projects the exists core.
Saves the project core.
| TimeSpan<!– System.TimeSpan –> |
| ProjectPlugin<!– ThinkGeo.MapSuite.GisEditor.ProjectPlugin –> |
| Event Arguments |
| Event Arguments |
Occurs when closed.
| Event Arguments |
| Event Arguments |
| Event Arguments |
Occurs when opened.
| Event Arguments |
| Event Arguments |
| Event Arguments |
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
