<!– Class –>
*System.Object System.EventArgs *ThinkGeo.MapSuite.GisEditor.LoadingPreviewImageProjectPluginManagerEventArgs
LoadingPreviewImageProjectPluginManagerEventArgs | Initializes a new instance of the class. | ||
LoadingPreviewImageProjectPluginManagerEventArgs | Image | Initializes a new instance of the class. |
Image | Image | Gets or sets the image. |
| image | Image<!– System.Drawing.Image –> | The image. |
<!– ThinkGeo.MapSuite.GisEditor.LoadingPreviewImageProjectPluginManagerEventArgs –> Go Back
