thinkgeo.mapsuite.giseditor.projectstreaminfo
ThinkGeo.MapSuite.GisEditor.ProjectStreamInfo
<!– Class –>
Public MethodProjectStreamInfo Initializes a new instance of the class.
Public MethodProjectStreamInfo Uri, MemoryStream Initializes a new instance of the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyStream MemoryStream Gets or sets the stream.
Public PropertyUri Uri Gets or sets the URI.
ProjectStreamInfo()
Name Type Description
Go Back
ProjectStreamInfo(Uri, MemoryStream)
uri Uri<!– System.Uri –> The URI.
stream MemoryStream<!– System.IO.MemoryStream –> The stream.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Stream
Return Type
<!– ThinkGeo.MapSuite.GisEditor.ProjectStreamInfo –> Go Back
Uri
Return Type
thinkgeo.mapsuite.giseditor.projectstreaminfo.txt · Last modified: 2017/03/16 21:59 (external edit)
