<!– Class –>
*System.Object System.EventArgs *ThinkGeo.MapSuite.GisEditor.OpenedProjectManagerEventArgs
OpenedProjectManagerEventArgs | Initializes a new instance of the class. | ||
OpenedProjectManagerEventArgs | ProjectStreamInfo, Exception | Initializes a new instance of the class. |
Error | Exception | Gets or sets the error. | |
ProjectStreamInfo | ProjectStreamInfo | Gets or sets the project stream info. |
| projectStreamInfo | ProjectStreamInfo<!– ThinkGeo.MapSuite.GisEditor.ProjectStreamInfo –> | The project stream info. |
| error | Exception<!– System.Exception –> | The error. |
<!– ThinkGeo.MapSuite.GisEditor.OpenedProjectManagerEventArgs –> Go Back
