thinkgeo.mapsuite.giseditor.openingprojectmanagereventargs
ThinkGeo.MapSuite.GisEditor.OpeningProjectManagerEventArgs
<!– Class –>
Public MethodOpeningProjectManagerEventArgs Initializes a new instance of the class.
Public MethodOpeningProjectManagerEventArgs ProjectStreamInfo Initializes a new instance of the class.
Public MethodOpeningProjectManagerEventArgs ProjectStreamInfo, Boolean Initializes a new instance of the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyIsCanceled Boolean Gets or sets a value indicating whether this instance is canceled.
Public PropertyProjectStreamInfo ProjectStreamInfo Gets or sets the project stream info.
OpeningProjectManagerEventArgs()
Name Type Description
Go Back
OpeningProjectManagerEventArgs(ProjectStreamInfo)
projectStreamInfo ProjectStreamInfo<!– ThinkGeo.MapSuite.GisEditor.ProjectStreamInfo –> The project stream info.
Go Back
OpeningProjectManagerEventArgs(ProjectStreamInfo, Boolean)
isCanceled Boolean<!– System.Boolean –> if set to true canceled.
Go Back
Return Type Description
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
IsCanceled
Return Type
<!– ThinkGeo.MapSuite.GisEditor.OpeningProjectManagerEventArgs –> Go Back
ProjectStreamInfo
Return Type
thinkgeo.mapsuite.giseditor.openingprojectmanagereventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
