<!– Class –> This class represents a plugin for project.
ProjectPlugin | Initializes a new instance of the class. |
ApplySettings | StorableSettings | Plugin | Applies the settings to this plugin. |
GetOpenProjectIcon | Gets the open project icon. | ||
GetProjectFullName | Uri | Gets the full name of the project. | |
GetProjectSaveAsUri | Gets the project save as URI. | ||
GetProjectShortName | Uri | Gets the short name of the project. | |
GetSaveProjectIcon | Gets the save project icon. | ||
GetSettings | Plugin | Gets plugin settings to save. | |
GetSettingsUI | Plugin | Gets an UI that configures settings. | |
Load | Plugin | This method raises when load this plugin. | |
LoadProjectStream | ProjectStreamInfo | Loads the project stream. | |
ProjectExists | Uri | Projects the exists. | |
SaveProjectStream | ProjectStreamInfo | Saves the project stream. | |
ToString | Object | ||
Unload | Plugin | This method raises when unload this plugin. |
ApplySettingsCore | StorableSettings | Plugin | Applies the settings to this plugin. |
GetOpenProjectIconCore | Gets the open project icon core. | ||
GetProjectFullNameCore | Uri | Gets the project full name core. | |
GetProjectSaveAsUriCore | Gets the project save as URI core. | ||
GetProjectShortNameCore | Uri | Gets the project short name core. | |
GetSaveProjectIconCore | Gets the save project icon core. | ||
GetSettingsCore | Plugin | Gets plugin settings to save. | |
GetSettingsUICore | Plugin | Gets an UI that configures settings. | |
LoadCore | Plugin | This method raises when load this plugin. | |
LoadProjectStreamCore | ProjectStreamInfo | Loads the project stream core. | |
MemberwiseClone | Object | ||
ProjectExistsCore | Uri | Projects the exists core. | |
SaveProjectStreamCore | ProjectStreamInfo | Saves the project stream core. | |
UnloadCore | Plugin | This method raises when unload this plugin. |
Author | String | Plugin | Gets or sets author information for plugin. |
Description | String | Plugin | Gets or sets description for plugin. |
Id | String | Plugin | Gets the identify of plugin. |
Index | Int32 | Plugin | Gets or sets the index of the plugin. |
IsActive | Boolean | Plugin | Gets or sets a value indicating whether this plugin is active. |
IsRequired | Boolean | Plugin | Gets or sets a value indicating whether this plugin is required. |
LargeIcon | ImageSource | Plugin | Gets or sets large icon for plugin. |
Name | String | Plugin | Gets or sets the name of plugin. |
SmallIcon | ImageSource | Plugin | Gets or sets small icon path for plugin. |
| settings | StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | The settings to be applied to this plugin. |
<!– ThinkGeo.MapSuite.GisEditor.Plugin –> Go Back
| ImageSource<!– System.Windows.Media.ImageSource –> | An icon for current project plugin |
<!– ThinkGeo.MapSuite.GisEditor.ProjectPlugin –> Go Back
| String<!– System.String –> | The project full name |
| projectUri | Uri<!– System.Uri –> | The project URI. |
| ProjectSaveAsResult<!– ThinkGeo.MapSuite.GisEditor.ProjectSaveAsResult –> | An project URI result |
| String<!– System.String –> | The project shut name |
| ImageSource<!– System.Windows.Media.ImageSource –> | An icon for saving project |
| StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | Plugin's settings to save. |
| SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> | A SettingUserControl that configures settings. |
| projectStreamInfo | ProjectStreamInfo<!– ThinkGeo.MapSuite.GisEditor.ProjectStreamInfo –> | The project stream info. |
| Boolean<!– System.Boolean –> | project exists |
| ImageSource<!– System.Windows.Media.ImageSource –> | An icon for open project |
| String<!– System.String –> | The project short name |
<remarks> Plugins are orded by this property. </remarks>
<remarks> Setting relative path to this property to discover image. Path should be like the form of FolderName(optional)/ImageFullName, such as “Images/NewContent.png” or “Content.png”. Make sure that image you supplied compiling with Build Action Resource. </remarks>
