<!– Class –> This class represents a project which can be saved as a result
*System.Object **ThinkGeo.MapSuite.GisEditor.ProjectSaveAsResult
ProjectSaveAsResult | Initializes a new instance of the class. | ||
ProjectSaveAsResult | Uri | Initializes a new instance of the class. | |
ProjectSaveAsResult | Uri, Boolean | Initializes a new instance of the class. |
| uri | Uri<!– System.Uri –> | The URI. |
| canceled | Boolean<!– System.Boolean –> | if set to true canceled. |
Gets or sets a value indicating whether this is canceled.
<!– ThinkGeo.MapSuite.GisEditor.ProjectSaveAsResult –> Go Back
Gets or sets the URI.
