thinkgeo.mapsuite.giseditor.taskpluginmanager
ThinkGeo.MapSuite.GisEditor.TaskPluginManager
<!– Class –>
Public MethodTaskPluginManager Initializes a new instance of the class.
Public MethodApplySettings StorableSettings Manager Applies the settings to this manager.
Public MethodGetActiveTaskPlugins
Public MethodGetPlugins PluginManager Gets the related plugins.
Public MethodGetSettings Manager Gets manager settings to save.
Public MethodGetSettingsUI Manager Gets an UI that configures settings.
Public MethodGetTaskPlugins
Public MethodGetType Object
Public MethodRunTask TaskPlugin Runs the task.
Public MethodToString Object
Public MethodUpdateTask String, TaskCommand Updates the task.
Protected MethodApplySettingsCore StorableSettings Manager Applies the settings to this manager.
Protected MethodGetPluginsCore PluginManager(overriden) Gets the plugins core.
Protected MethodGetSettingsCore Manager Gets manager settings to save.
Protected MethodGetSettingsUICore Manager Gets an UI that configures settings.
Protected MethodOnUpdatingProgress UpdatingTaskProgressEventArgs Raises the event.
Protected MethodRunTaskCore TaskPlugin Runs the task core.
Protected MethodUpdateProgressCore UpdatingTaskProgressEventArgs Updates the progress core.
Protected MethodUpdateTaskCore String, TaskCommand Updates the task core.
Public PropertyRunProcessesLocally Boolean Gets or sets a value indicating whether processes locally.
Public EventUpdatingProgress UpdatingTaskProgressEventArgs Occurs when progress.
TaskPluginManager()
Name Type Description
Go Back
ApplySettings(StorableSettings)
Return Type Description
Void<!– System.Void –>
settings StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> The settings to be applied to this manager.
<!– ThinkGeo.MapSuite.GisEditor.Manager –> Go Back
Boolean<!– System.Boolean –>
GetActiveTaskPlugins()
Collection<T><!– Collection{T} –>
<!– ThinkGeo.MapSuite.GisEditor.TaskPluginManager –> Go Back
Collection<TaskPlugin><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.TaskPlugin} –>
Int32<!– System.Int32 –>
GetPlugins()
Collection<Plugin><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.GisEditor.Plugin} –>
<!– ThinkGeo.MapSuite.GisEditor.PluginManager –> Go Back
GetSettings()
StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> Manager's settings to save
GetSettingsUI()
SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> A SettingUserControl that configures settings.
GetTaskPlugins()
Type<!– System.Type –>
RunTask(TaskPlugin)
Runs the task.
String<!– System.String –>
taskPlugin TaskPlugin<!– ThinkGeo.MapSuite.GisEditor.TaskPlugin –> The task plugin.
UpdateTask(String, TaskCommand)
Updates the task.
taskToken String<!– System.String –> The task token.
taskCommand TaskCommand<!– ThinkGeo.MapSuite.GisEditor.TaskCommand –> The task command.
ApplySettingsCore(StorableSettings)
GetPluginsCore()
<!– ThinkGeo.MapSuite.GisEditor.PluginManager(overriden) –> Go Back
GetSettingsCore()
GetSettingsUICore()
OnUpdatingProgress(UpdatingTaskProgressEventArgs)
Raises the event.
e UpdatingTaskProgressEventArgs<!– ThinkGeo.MapSuite.GisEditor.UpdatingTaskProgressEventArgs –> The instance containing the event data.
RunTaskCore(TaskPlugin)
Runs the task core.
UpdateProgressCore(UpdatingTaskProgressEventArgs)
UpdateTaskCore(String, TaskCommand)
RunProcessesLocally
Return Type
UpdatingProgress
Event Arguments
Event Arguments
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
thinkgeo.mapsuite.giseditor.taskpluginmanager.txt · Last modified: 2017/03/16 21:59 (external edit)
