thinkgeo.mapsuite.giseditor.taskplugin
ThinkGeo.MapSuite.GisEditor.TaskPlugin
<!– Class –>
Protected MethodTaskPlugin Initializes a new instance of the class.
Public MethodApplySettings StorableSettings Plugin Applies the settings to this plugin.
Public MethodGetSettings Plugin Gets plugin settings to save.
Public MethodGetSettingsUI Plugin Gets an UI that configures settings.
Public MethodGetType Object
Public MethodLoad Plugin This method raises when load this plugin.
Public MethodRun Runs this instance.
Public MethodToString Object
Public MethodUnload Plugin This method raises when unload this plugin.
Protected MethodApplySettingsCore StorableSettings Plugin Applies the settings to this plugin.
Protected MethodGetSettingsCore Plugin Gets plugin settings to save.
Protected MethodGetSettingsUICore Plugin Gets an UI that configures settings.
Protected MethodLoadCore Plugin(overriden) This method raises when load this plugin.
Protected MethodOnUpdatingProgress UpdatingTaskProgressEventArgs Raises the event.
Protected MethodRunCore Runs the core.
Protected MethodUnloadCore Plugin This method raises when unload this plugin.
Public PropertyAuthor String Plugin Gets or sets author information for plugin.
Public PropertyDescription String Plugin Gets or sets description for plugin.
Public PropertyId String Plugin Gets the identify of plugin.
Public PropertyIndex Int32 Plugin Gets or sets the index of the plugin.
Public PropertyIsActive Boolean Plugin Gets or sets a value indicating whether this plugin is active.
Public PropertyIsRequired Boolean Plugin Gets or sets a value indicating whether this plugin is required.
Public PropertyLargeIcon ImageSource Plugin Gets or sets large icon for plugin.
Public PropertyName String Plugin Gets or sets the name of plugin.
Public PropertySmallIcon ImageSource Plugin Gets or sets small icon path for plugin.
Public EventUpdatingProgress UpdatingTaskProgressEventArgs Occurs when progress.
TaskPlugin()
Name Type Description
Go Back
ApplySettings(StorableSettings)
Return Type Description
Void<!– System.Void –>
settings StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> The settings to be applied to this plugin.
<!– ThinkGeo.MapSuite.GisEditor.Plugin –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetSettings()
StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> Plugin's settings to save.
GetSettingsUI()
SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> A SettingUserControl that configures settings.
Type<!– System.Type –>
Load()
Run()
Runs this instance.
<!– ThinkGeo.MapSuite.GisEditor.TaskPlugin –> Go Back
String<!– System.String –>
Unload()
ApplySettingsCore(StorableSettings)
GetSettingsCore()
GetSettingsUICore()
LoadCore()
<!– ThinkGeo.MapSuite.GisEditor.Plugin(overriden) –> Go Back
OnUpdatingProgress(UpdatingTaskProgressEventArgs)
Raises the event.
e UpdatingTaskProgressEventArgs<!– ThinkGeo.MapSuite.GisEditor.UpdatingTaskProgressEventArgs –> The instance containing the event data.
RunCore()
Runs the core.
UnloadCore()
Author
Return Type
Description
Return Type
Id
Return Type
Index
<remarks> Plugins are orded by this property. </remarks>
Return Type
IsActive
Return Type
IsRequired
Return Type
LargeIcon
<remarks> Setting relative path to this property to discover image. Path should be like the form of FolderName(optional)/ImageFullName, such as “Images/NewContent.png” or “Content.png”. Make sure that image you supplied compiling with Build Action Resource. </remarks>
Return Type
ImageSource<!– System.Windows.Media.ImageSource –>
Return Type
SmallIcon
Return Type
UpdatingProgress
Event Arguments
Event Arguments
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
thinkgeo.mapsuite.giseditor.taskplugin.txt · Last modified: 2017/03/16 21:59 (external edit)
