<!– Class –>
*System.Object System.EventArgs *ThinkGeo.MapSuite.GisEditor.UpdatingTaskProgressEventArgs
UpdatingTaskProgressEventArgs | Initializes a new instance of the class. | ||
UpdatingTaskProgressEventArgs | TaskState | Initializes a new instance of the class. | |
UpdatingTaskProgressEventArgs | TaskState, Int32 | Initializes a new instance of the class. | |
UpdatingTaskProgressEventArgs | TaskState, Int32, Object | Initializes a new instance of the class. | |
UpdatingTaskProgressEventArgs | TaskState, Int32, Object, String | Initializes a new instance of the class. |
Current | Int32 | Gets or sets the current. | |
Error | ExceptionInfo | Gets or sets the error. | |
Message | String | Gets or sets the message. | |
Parameters | Dictionary<String,String> | Gets the parameters. | |
ProgressPercentage | Int32 | Gets the progress percentage. | |
TaskState | TaskState | Gets or sets the state of the task. | |
TaskToken | String | Gets or sets the task token. | |
UpperBound | Int32 | Gets or sets the upper bound. | |
UserState | Object | Gets the state of the user. |
| taskState | TaskState<!– ThinkGeo.MapSuite.GisEditor.TaskState –> | State of the task. |
| progressPercentage | Int32<!– System.Int32 –> | The progress percentage. |
| userState | Object<!– System.Object –> | State of the user. |
| taskToken | String<!– System.String –> | The task token. |
<!– ThinkGeo.MapSuite.GisEditor.UpdatingTaskProgressEventArgs –> Go Back
| ExceptionInfo<!– ThinkGeo.MapSuite.GisEditor.ExceptionInfo –> |
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
