map_suite_desktop_for_wpf_miscellaneous_samples
Wpf Samples
Show A Legend Sample for Wpf
In today’s project we learn how to display a simple legend using the new and improved LegendAdornmentLayer. The improved LegendAdornmentLayer was added to Map Suite 5.0 and provides an easy to use API for creating legend adornments. The LegendAdornmentLayer is part of Map Suite Core which allows you to access this powerful feature across all Map Suite products.
Screenshot
View this sample on Github
Labeling Flight Lines Sample for Wpf
This sample shows how to offset arc shaped flight lines so multiple from point to point are visible and then show popup labels providing information on the flights the lines represent.
Screenshot
Find Nearest Cross Streets Sample for Wpf
Screenshot
map_suite_desktop_for_wpf_miscellaneous_samples.txt · Last modified: 2020/03/08 06:40 (external edit)
