thinkgeo.mapsuite.iosedition.featureresizingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.iOSEdition.FeatureResizingEditInteractiveOverlayEventArgs
Provides data for the FeatureResizing. event.
      • ThinkGeo.MapSuite.iOSEdition.FeatureResizingEditInteractiveOverlayEventArgs
FeatureResizingEditInteractiveOverlayEventArgs()
FeatureResizingEditInteractiveOverlayEventArgs(Feature,Boolean,PointShape,PointShape)
  • resizingFeature
    • Type:Feature
    • Description:This parameter specified the target feature to be resized.
  • cancel
  • sourceControlPoint
    • Description:This parameter specified the source control point to be resized.
  • targetControlPoint
    • Description:This parameter specified the target control point to be resized.
ResizingFeature
This property gets or sets the Feature to be used to resized.
SourceControlPoint
This property gets or sets the source control point to resize.
TargetControlPoint
This property gets or sets the target control point to resize.
Cancel
thinkgeo.mapsuite.iosedition.featureresizingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
