thinkgeo.mapsuite.silverlightedition.openstreetmapoverlay
ThinkGeo.MapSuite.SilverlightEdition.OpenStreetMapOverlay
This class represents the OpenStreetMapOverlay which requests images from OpenStreetMap's image server.
    • ThinkGeo.MapSuite.SilverlightEdition.Overlay
      • ThinkGeo.MapSuite.SilverlightEdition.OpenStreetMapOverlay
OpenStreetMapOverlay()
  • This is constructor of OpenStreetMapOverlay class.
OpenStreetMapOverlay(String)
  • name
    • Description:A string value indicating the name of this overlay.
Initialize(Map)
  • This method initializes the overlay canvas such as width, height and z-index for first time.
  • currentMap
    • Type:Map
Draw(RectangleShape,OverlayDrawType)
  • This method draws the features in the specified extent.
  • worldExtent
  • overlayDrawType
    • Description:The enum value indecating that the map draws features or not.
Refresh()
ToWorldCoordinate(Double,Double)
  • screenX
  • screenY
ToWorldCoordinate(PointShape)
  • screenCoordinate
ToWorldCoordinate(Point)
  • screenCoordinate
    • Type:Point
ToScreenCoordinate(Double,Double)
  • worldX
  • worldY
ToScreenCoordinate(PointShape)
ToScreenCoordinate(Point)
  • worldCoordinate
    • Type:Point
InitializeCore()
DrawCore(RectangleShape)
  • worldExtent
    • Description:A RectangleShape value indicating the world extent need to draw.
GetTileUri(RectangleShape,Int32,Int32,Int32,Int32,Double)
  • This method gets the uri address which uses for requesting images from Wms server.
  • Type:Uri
  • Description:An uri address which uses for requesting images from Wms server.
  • tileExtent
    • Description:A RectangleShape value indicating the tile extent which uses for requesting images from wms server.
  • row
    • Description:An integar value indicating the row index of the tile in the world extent.
  • column
  • tileWidth
    • Description:A double value indicating the width in pixel of the tile.
  • tileHeight
    • Description:A double value indicating the height in pixel of the tile.
  • scale
    • Description:A double value indicating current scale of the requesting tile.
LxU=(RectangleShape)
MBU=(Image,RectangleShape)
  • image
    • Type:Image
DxU=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
ZoomStoryCompletedCore()
PanAnimationCompletedCore()
IsStretchEffectDisabled
Gets or sets whether the stretch effect is disabled or not.
If the wms images are transparent background, the stretched tiles will display right below the real tiles by the default value which affects your map.
CustomServerUris
  • Type:Collection<Uri>
Visibility
  • Type:Visibility
OverlayElement
  • Type:FrameworkElement
Attribution
TransitionEffect
Opacity
ZIndex
StoryboardForZooming
  • Type:Storyboard
StoryboardForPanning
  • Type:Storyboard
PanFrameX
  • Type:SplineDoubleKeyFrame
PanFrameY
ZoomFrameX
ZoomFrameY
MapInfo
TranslateTransform
  • Type:TranslateTransform
ScaleTransform
  • Type:ScaleTransform
TransformGroup
  • Type:TransformGroup
DrawingAttribution N/A
Event Arguments:DrawingAttributionOverlayEventArgs
DrawnAttribution N/A
Event Arguments:DrawnAttributionOverlayEventArgs
thinkgeo.mapsuite.silverlightedition.openstreetmapoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
