thinkgeo.mapsuite.silverlightedition.map
ThinkGeo.MapSuite.SilverlightEdition.Map
This class represents the main Silverlight map control.
    • System.Windows.DependencyObject
      • System.Windows.UIElement
        • System.Windows.FrameworkElement
          • System.Windows.Controls.Panel
            • System.Windows.Controls.Canvas
              • ThinkGeo.MapSuite.SilverlightEdition.Map
Map()
  • This is the constructor of Map class.
  • The map class inherits from the Canvas control, so it can be defined onto the page or be created and added to a page via code like the Canvas control itself. You also need to configure the properties of the map. The most important step is adding overlays, which generate images, shapes, and stack them over each other to form a map. The map control has many methods and events through which you can interact with it.
Refresh()
  • This method refreshes all the overlays and map tools configed on the map.
  • This method refreshes all the overlays and map tools configed on the map. Please call it when your change related properties such as overlays and styles.
  • Description:None
ZoomIn()
  • This method zooms the map in to the next scale of the ClientZoomLevelScales collection.
  • This method zooms the map in to the next scale of the ClientZoomLevelScales collection.If the new scale is the last scale in the collection, it keeps current level and does not change.
ZoomOut()
  • This method zooms the map out to the previous scale in the ClientZoomLevelScales collection.
  • This method zooms the map out to the previous scale in the ClientZoomLevelScales collection.If the new scale is the first scale in the collection, it keeps current level and does not change.
ZoomToScale(Double)
  • This method zooms the map to a specific scale.
  • This method will not affect the center of the map. It zooms the map to the zoomlevel whose scale is larger and nearest to the scale specified. For example, if you specify a scale that is between two zoomlevels, the map will snap to the nearest upper zoomlevel. So the map's final scale might not be equal to the specified scale after you call this method.
  • targetScale
    • Description:The new scale the map will zoom to. If the specific target scale is now in the ClientZoomLevelScales, it automatically snaps to the closest level.
ZoomTo(PointShape,Int32)
  • This method zooms the map to the center point and the client zoomlevel number that you specify.
  • The map will be panned to the new center and zoomed to the zoomlevel number compare to the ClientZoomScales that you specify.
  • targetCenter
    • Description:The target world center pointShape of the map.
  • zoomLevelId
    • Description:The target zoomlevel index that the map will zoom to.
ZoomTo(Point,Int32)
  • targetCenter
    • Type:Point
    • Description:The target world center point of the map.
  • zoomLevelId
ZoomTo(RectangleShape)
  • This method zooms the map to the extent that you specify.
  • The map will be panned to the center and zoomlevel of the extent that you specify.
  • targetWorldExtent
MoveTo(PointShape)
  • This method moves the map to the center PointShape that you specify.
  • This method moves the map to the center PointShape that you specify. It keeps current scale.
  • targetCenter
    • Description:The target world center PointShape of the map.
MoveTo(Point)
  • This method moves the map to the center that you specify.
  • This method moves the map to the center that you specify. It keeps current scale.
  • targetCenter
    • Type:Point
    • Description:The target world center Point of the map.
Pan(Single,Int32)
  • This method moves the map by the specified angle and the percentage of the current extent.
  • This method moves the map by the angle and the percentage that you specify.The angle starts from the east and increases counterclockwise. For example, angle 0 represents precisely east and angle 90 represents precisely north.The percentage specifies the offset related to the current extent. If the percentage is 20, the panning offset in the X direction is CurrentExtent.Width* 0.2 and the offset in the Y direction is CurrentExtent.Height*0.2.
  • degree
    • Type:Single
    • Description:The angle value that determines the panning direction.
  • percentage
    • Description:The percentage of the current extent.
Pan(PanDirection,Int32)
  • panDirection
  • percentage
Pan(Double,Double)
  • This method move the map by the offset of the current extent.
  • offsetScreenX
    • Description:The x offset in screen coordinate that determines the panning.
  • offsetScreenY
    • Description:The y offset in screen coordinate that determines the panning.
GetScaleFromZoomLevelId(Int32)
  • This method gets scale from the zoomLevel index.
  • Description:Returns the scale of the zoomLevelId that you defined in the ClientZoomLevelScales.
  • zoomLevelId
    • Description:ZoomLevel index in the ClientZoomLevelScales collection.
GetResolutionFromZoomLevelId(Int32)
  • This method gets resolution from the zoomLevel index from the ClientZoomLevelScales.
  • This method gets resolution from the zoomLevel index from the ClientZoomLevelScales.Resolution = world coordinate length per screen pixel.
  • Description:The resolution of the zoomLevelId that you defined in the ClientZoomLevelScales.
  • zoomLevelId
    • Description:The zoom level index in the ClientZoomLevelScales collection.
GetClosestZoomLevelIdFromScale(Double)
  • This method gets closest zoomLevel index from the scale.
  • This method gets closest zoomLevel index from the scale.It returns the map zoomlevel index whose scale is nearest to the ClientZoomLevelScales specified.
  • Description:The closest zoomLevel index that you defined in the ClientZoomLevelScales.
  • scale
    • Description:A double value of scale to get the closest zoomLevel index.
GetClosestZoomLevelIdFromResolution(Double)
  • This method gets closest zoomLevel index from the resolution.
  • It returns the map zoomlevel whose resolution is nearest to the ClientZoomLevelScales specified.Resolution = world coordinate length per screen pixel.
  • resolution
    • Description:A double value of resolution to get the closest zoomLevel index.
ToWorldCoordinate(Double,Double)
  • This method converts a specified X, Y screen coordinates to a point shape in world coordinates.
  • This method converts X, Y screen coordinates to a point shape in world coodinates.
  • Description:A point shape in world coordinates.
  • screenX
    • Description:The X-value in pixels referenced to the screen origin.
  • screenY
    • Description:The Y-value in pixels referenced to the screen origin.
ToWorldCoordinate(PointShape)
  • This method converts a PointShape in screen coordinates to a point shape in world coordinates.
  • This method converts a screen point to a point in world coordinates.
  • screenCoordinate
    • Description:The point (in screen coordinates) to convert to world coordinates.
ToWorldCoordinate(Point)
  • This method converts a point shape in world coordinates from a ScreenPointF structure.
  • screenCoordinate
    • Type:Point
ToScreenCoordinate(Double,Double)
  • This method converts a specified X, Y world coordinates to a point shape in screen coordinates.
  • This method converts X, Y world coordinates to a point in screen coordinates.
  • Description:A screen point in pixels.
  • worldX
    • Description:The X world coordinate.
  • worldY
    • Description:The Y world coordinate.
ToScreenCoordinate(PointShape)
  • This method converts a specified PointShape in world coordinates to a point shape in screen coordinates.
  • This method converts the coordinates of a point shape to a point in screen coordinates.
  • worldCoordinate
ToScreenCoordinate(Point)
  • worldCoordinate
    • Type:Point
    • Description:A point in world coordinates.
FindName(String)
  • name
OnApplyTemplate()
SetBinding(DependencyProperty,Binding)
  • Type:BindingExpressionBase
  • dp
    • Type:DependencyProperty
  • binding
    • Type:Binding
GetBindingExpression(DependencyProperty)
  • dp
AddHandler(RoutedEvent,Delegate,Boolean)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
  • handledEventsToo
RemoveHandler(RoutedEvent,Delegate)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
TransformToVisual(UIElement)
  • Type:GeneralTransform
  • visual
    • Type:UIElement
Measure(Size)
  • availableSize
    • Type:Size
Arrange(Rect)
  • finalRect
    • Type:Rect
CaptureMouse()
ReleaseMouseCapture()
InvalidateMeasure()
InvalidateArrange()
UpdateLayout()
CheckAccess()
SetValue(DependencyProperty,Object)
  • dp
  • value
ClearValue(DependencyProperty)
  • dp
ReadLocalValue(DependencyProperty)
  • dp
GetAnimationBaseValue(DependencyProperty)
  • dp
GetValue(DependencyProperty)
  • dp
eRQ=(Point,Int32)
  • targetCenter
    • Type:Point
  • zoomLevel
YhQ=(PointShape,Int32,OverlayDrawType)
  • zoomLevelId
YhQ=(Point,Int32,OverlayDrawType)
  • targetCenter
    • Type:Point
  • zoomLevelId
ZRQ=(Single,Int32,OverlayDrawType)
  • degree
    • Type:Single
  • percentage
ZRQ=(Double,Double,OverlayDrawType)
  • offsetScreenX
  • offsetScreenY
OnClick(MapClickEventArgs)
  • This method raises the Click event of the Map object.
  • The OnClick method also allows derived classes to handle the event without attaching a delegate. This is the preferred technique for handling the event in a derived class.Notes to Inheritors: When overriding OnClick in a derived class, be sure to call the base class's OnClick method so that registered delegates receive the event.
  • e
OnDoubleClick(MapClickEventArgs)
  • This method raises the DoubleClick event of the Map object.
  • The DoubleClick method also allows derived classes to handle the event without attaching a delegate. This is the preferred technique for handling the event in a derived class.Notes to Inheritors: When overriding OnDoubleClick in a derived class, be sure to call the base class's OnDoubleClick method so that registered delegates receive the event.
  • e
OnExtentChanging(ExtentChangingEventArgs)
  • This method raises the ExtentChanging event of the Map object.
  • The OnExtentChanging method also allows derived classes to handle the event without attaching a delegate. This is the preferred technique for handling the event in a derived class.Notes to Inheritors: When overriding OnExtentChanging in a derived class, be sure to call the base class's OnExtentChanging method so that registered delegates receive the event.
OnExtentChanged(ExtentChangedEventArgs)
  • This event raises the ExtentChanged event of the Map object.
  • The OnExtentChanged method also allows derived classes to handle the event without attaching a delegate. This is the preferred technique for handling the event in a derived class.Notes to Inheritors: When overriding OnExtentChanged in a derived class, be sure to call the base class's OnExtentChanged method so that registered delegates receive the event.
MeasureOverride(Size)
  • Type:Size
  • constraint
    • Type:Size
ArrangeOverride(Size)
  • Type:Size
  • arrangeSize
    • Type:Size
ApplyTemplateInternal()
GetValueInternal(DependencyProperty)
  • dp
OnTreeParentUpdated(DependencyObject,Boolean)
  • newParent
    • Type:DependencyObject
  • bIsNewParentAlive
NotifyDataContextChanged(DataContextChangedEventArgs)
  • e
    • Type:DataContextChangedEventArgs
OnBindingValidationError(ValidationErrorEventArgs)
  • args
    • Type:ValidationErrorEventArgs
CalculateBubblePath()
  • Type:List<FrameworkElement>
RaiseBindingValidationError(ValidationErrorEventArgs)
  • args
OnSizeChanged(Object,SizeChangedEventArgs)
  • sender
  • e
    • Type:SizeChangedEventArgs
OnAncestorDataContextChanged(DataContextChangedEventArgs)
  • e
IsDataContextChangeRelevant(DataContextChangedEventArgs)
  • e
OnDataContextChanged(DataContextChangedEventArgs)
  • e
OnPropertyChanged(DependencyProperty)
  • dp
GetValueFromStyle(DependencyProperty,Object&)
  • property
  • value
    • Type:Object&
HasFocus()
FindNameInPage(String,Boolean)
  • name
  • calledFromUserControl
GetPlainText()
HitTest(Point)
  • Type:IEnumerable<UIElement>
  • point
    • Type:Point
HitTest(Rect)
  • rect
    • Type:Rect
IsAncestorOf(UIElement)
  • element
    • Type:UIElement
OnCreateAutomationPeer()
  • Type:AutomationPeer
GetOrCreateAutomationPeer()
GetAutomationPeer()
InvalidateAutomationPeer()
GetChildrenCount()
GetChild(Int32)
  • Type:UIElement
  • childIndex
BringIntoView()
BringIntoView(Rect)
  • targetRectangle
    • Type:Rect
GetIsUnloadingNode()
PegManagedPeerNoRef()
UnpegManagedPeerNoRef()
GetManagedReference(UInt32)
  • nPropertyID
    • Type:UInt32
RefreshExpression(DependencyProperty)
  • dp
EnsureValueTable()
SetValueInternal(DependencyProperty,Object)
  • dp
  • value
SetValueInternal(DependencyProperty,Object,Boolean)
  • dp
  • value
  • allowReadOnlySet
SetValueInternal(DependencyProperty,Object,Boolean,Boolean)
  • dp
  • value
  • allowReadOnlySet
  • isBindingInStyleSetter
ClearValueInternal(DependencyProperty)
  • dp
ReadLocalValueInternal(DependencyProperty)
  • dp
IsPropertyDefault(DependencyProperty)
  • dp
GetMentor()
  • Type:FrameworkElement
PrepareCorePropertyExpression(DependencyProperty,Object)
  • property
  • value
InvalidateStyleBinding(DependencyProperty,Boolean&)
  • dp
  • hasLocalOrAnimatedValue
    • Type:Boolean&
SetValue(DependencyProperty,Matrix)
  • property
  • m
    • Type:Matrix
SetValue(DependencyProperty,Matrix3D)
  • property
  • m
    • Type:Matrix3D
SetValue(DependencyProperty,Point)
  • property
  • p
    • Type:Point
SetValue(DependencyProperty,DependencyObject)
  • property
  • doh
SetValue(DependencyProperty,Int32)
  • property
  • i
SetValue(DependencyProperty,Boolean)
  • property
  • b
SetValue(DependencyProperty,Enum)
  • property
  • e
    • Type:Enum
SetValue(DependencyProperty,Color)
  • property
  • c
    • Type:Color
SetValue(DependencyProperty,Double)
  • property
  • d
SetValue(DependencyProperty,GridLength)
  • property
  • g
    • Type:GridLength
InvalidateProperty(DependencyProperty)
  • property
GetOldValue(DependencyProperty,EffectiveValueEntry&)
  • property
  • oldEntry
    • Type:EffectiveValueEntry&
GetNewValue(DependencyProperty,EffectiveValueEntry&)
  • property
  • newEntry
SetEffectiveValue(DependencyProperty,EffectiveValueEntry&,Object)
  • property
  • newEntry
  • newValue
UpdateParentInheritanceContextPropagation()
SetAnimatedValue(DependencyProperty,Object)
  • property
  • animatedValue
ClearAnimatedValue(DependencyProperty,Boolean,Object)
  • property
  • hasHoldEndValue
  • holdEndValue
GetValueFromBuiltInStyle(DependencyProperty,Object&)
  • property
  • value
    • Type:Object&
OnInheritanceContextChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
AddEventListener(DependencyProperty,Delegate)
  • property
  • handler
    • Type:Delegate
AddEventListener(DependencyProperty,Delegate,Boolean)
  • property
  • handler
    • Type:Delegate
  • handledEventsToo
RemoveEventListener(DependencyProperty,Delegate)
  • property
  • handler
    • Type:Delegate
UpdateTreeParent(IManagedPeer,IManagedPeer,Boolean,Boolean)
  • oldParent
    • Type:IManagedPeer
  • newParent
    • Type:IManagedPeer
  • bIsNewParentAlive
  • keepReferenceToParent
UpdateTreeParentHelper(IManagedPeer,IManagedPeer,Boolean)
  • oldParent
    • Type:IManagedPeer
  • newParent
    • Type:IManagedPeer
IsPropertyLocal(CoreDependencyProperty)
  • dp
    • Type:CoreDependencyProperty
OnParentEnter(IntPtr,UInt32,UInt32,UInt32,UInt32)
  • nativeNamescopeOwner
    • Type:IntPtr
  • bLive
    • Type:UInt32
  • bSkipNameRegistration
    • Type:UInt32
  • bCoercedIsEnabled
    • Type:UInt32
  • bUseLayoutRounding
    • Type:UInt32
ZoomLevelSet
Overlays
Gets an Overlay collection which you can add different types of overlays.
You can create any type of Overlay object and add it to the Overlays collection. The overlays will be stack by its adding order.
MapTools
Gets an object that contains all types of predefined map controls.
The property returns an object that contains all types of predefined map controls. Such as mouse coordinates etc.
ActiveBaseOverlay
Gets or sets the active base overlay.
The map can contain multiple base overlays, though only one of them can be displayed at a time. The ActiveBaseOverlay property specifies the one that is currently displayed. When you switch the base overlays in the OverlaySwitcher, the currently selected overlay will be synchronized to this property after postback.
CurrentZoomLevelId
Gets a integar value that indicates current zoom level id.
CurrentScale
Gets a double value that indicates the current scale of the map.
CurrentResolution
Gets a double value that indicates the current resolution of the map.
CurrentExtent
Gets or sets the current extent of the map.
RestrictedExtent
Gets or sets the restricted extent of the map.
MaxExtent
Gets the max extent of the map in current map unit.
CurrentCenter
Gets a PointShape value that indicates current center of the map.
Popups
Gets a Popup collection that holds all the popups in the map.
Gets a grid panel for maintaining map tools. The tools are layouted by the column and row index in the Grid Panel.It accepts the custom Silverlight controls as well.
  • Type:Grid
ExtentInteractiveOverlay
Gets or sets an InteractiveOverlay which mantains the navigation of the map.
Gets or sets an InteractiveOverlay which mantains the navigation of the map such as panning, zooming etc.
TrackOverlay
Gets or sets an InteractiveOverlay which maintain the algorism of Tracking Shape.
Gets or sets an InteractiveOverlay which maintain the algorism of Tracking.
EditOverlay
Gets or sets an InteractiveOverlay which maintain the algorism of Editing.
Gets or sets an InteractiveOverlay which maintain the algorism of Editing Shape.
Children
  • Type:UIElementCollection
Background
  • Type:Brush
IsItemsHost
Triggers
  • Type:TriggerCollection
Resources
  • Type:ResourceDictionary
ActualWidth
ActualHeight
Width
Height
MinWidth
MaxWidth
MinHeight
MaxHeight
HorizontalAlignment
  • Type:HorizontalAlignment
VerticalAlignment
  • Type:VerticalAlignment
Margin
  • Type:Thickness
Style
  • Type:Style
Parent
FlowDirection
  • Type:FlowDirection
Tag
Cursor
  • Type:Cursor
Language
  • Type:XmlLanguage
DataContext
AllowDrop
Opacity
Clip
  • Type:Geometry
Effect
  • Type:Effect
Projection
  • Type:Projection
OpacityMask
  • Type:Brush
RenderTransformOrigin
  • Type:Point
IsHitTestVisible
Visibility
  • Type:Visibility
RenderSize
  • Type:Size
UseLayoutRounding
CacheMode
  • Type:CacheMode
DesiredSize
  • Type:Size
RenderTransform
  • Type:Transform
Dispatcher
  • Type:Dispatcher
XBQ=
  • Type:Collection<Double>
XhQ=
  • Type:Canvas
TagInternal
TemplatedParent
IsDataContextBound
IsDataContextChangingInternal
ChildrenInternal
NativeObject
  • Type:IntPtr
NativeObjectSafeHandle
  • Type:NativeObjectSafeHandle
NeedsInheritanceContextChanges
IsInLiveTree
ExtentChanging This event is raised before current extent of map changing.
This event is raised when the map's extent is about to change. In the event argument, it contains current extent and current scale of the map.
Event Arguments:ExtentChangingEventArgs
ExtentChanged This event is raised after map's extent changed.
This event is raised after the map's current extent changed. In the event arguments, it contains the new extent and new scale of the map.
Event Arguments:ExtentChangedEventArgs
Click This event is raised when the map is clicked.
This event is raised when the map is clicked. In the event argument, it contains current clicked point in world coordinates and screen coordinates.
Event Arguments:MapClickEventArgs
DoubleClick This event is raised when the map is double clicked.
This event is raised when the map is double clicked.In the event argument, it contains current clicked point in world coordinates and screen coordinates.When the click event and double click event are both hooked, only double click event will be raised.
Loaded N/A
Event Arguments:
Unloaded N/A
Event Arguments:
SizeChanged N/A
Event Arguments:
LayoutUpdated N/A
Event Arguments:
BindingValidationError N/A
Event Arguments:ValidationErrorEventArgs
DataContextChanged N/A
Event Arguments:
MouseMove N/A
Event Arguments:
MouseEnter N/A
Event Arguments:
MouseLeave N/A
Event Arguments:
MouseLeftButtonDown N/A
Event Arguments:
MouseLeftButtonUp N/A
Event Arguments:
MouseRightButtonDown N/A
Event Arguments:
MouseRightButtonUp N/A
Event Arguments:
MouseWheel N/A
Event Arguments:
KeyUp N/A
Event Arguments:
KeyDown N/A
Event Arguments:
MediaCommand N/A
Event Arguments:
GotFocus N/A
Event Arguments:
LostFocus N/A
Event Arguments:
LostMouseCapture N/A
Event Arguments:
TextInput N/A
Event Arguments:
TextInputStart N/A
Event Arguments:
TextInputUpdate N/A
Event Arguments:
DragEnter N/A
Event Arguments:
DragLeave N/A
Event Arguments:
DragOver N/A
Event Arguments:
Drop N/A
Event Arguments:
ManipulationStarted N/A
Event Arguments:ManipulationStartedEventArgs
ManipulationDelta N/A
Event Arguments:ManipulationDeltaEventArgs
ManipulationCompleted N/A
Event Arguments:ManipulationCompletedEventArgs
Tap N/A
Event Arguments:GestureEventArgs
DoubleTap N/A
Hold N/A
thinkgeo.mapsuite.silverlightedition.map.txt · Last modified: 2017/03/16 21:59 (external edit)
