thinkgeo.mapsuite.silverlightedition.extentinteractiveoverlay
ThinkGeo.MapSuite.SilverlightEdition.ExtentInteractiveOverlay
This class inherits from InterativeOverlay abstract class. This specified overlay describle the Extent Changing interative process with MapControl using Mouse or Keyborad.
    • ThinkGeo.MapSuite.SilverlightEdition.Overlay
      • ThinkGeo.MapSuite.SilverlightEdition.InteractiveOverlay
        • ThinkGeo.MapSuite.SilverlightEdition.ExtentInteractiveOverlay
ExtentInteractiveOverlay()
  • Default constructor of the class. If you use thi constructor, please set the properties correctly or it will use their default values.
MouseDown(InteractionArguments)
MouseMove(InteractionArguments)
MouseUp(InteractionArguments)
MouseClick(InteractionArguments)
MouseDoubleClick(InteractionArguments)
MouseWheel(InteractionArguments)
Refresh()
Draw(RectangleShape,OverlayDrawType)
Initialize(Map)
  • currentMap
    • Type:Map
ToWorldCoordinate(Double,Double)
  • screenX
  • screenY
ToWorldCoordinate(PointShape)
  • screenCoordinate
ToWorldCoordinate(Point)
  • screenCoordinate
    • Type:Point
ToScreenCoordinate(Double,Double)
  • worldX
  • worldY
ToScreenCoordinate(PointShape)
ToScreenCoordinate(Point)
  • worldCoordinate
    • Type:Point
InitializeCore()
  • This method initializes the overlay canvas such as width, height and z-index for first time.
MouseDownCore(InteractionArguments)
  • This overrides the MouseDown logic in its base class InterativeOverlay.
  • interactionArguments
MouseMoveCore(InteractionArguments)
  • This overrides the MouseMove logic in its base class InterativeOverlay.
MouseUpCore(InteractionArguments)
  • This overrides the MouseUp logic in its base class InterativeOverlay.
MouseWheelCore(InteractionArguments)
  • This overrides the MouseWheel logic in its base class InterativeOverlay.
MouseDoubleClickCore(InteractionArguments)
  • This overrides the MouseDoubleClick logic in its base class InterativeOverlay.
MouseClickCore(InteractionArguments)
OnMapMouseDown(MapMouseDownInteractiveOverlayEventArgs)
OnMapMouseMove(MapMouseMoveInteractiveOverlayEventArgs)
OnMapMouseUp(MapMouseUpInteractiveOverlayEventArgs)
OnMapMouseClick(MapMouseClickInteractiveOverlayEventArgs)
OnMapMouseDoubleClick(MapMouseDoubleClickInteractiveOverlayEventArgs)
OnMapMouseWheel(MapMouseWheelInteractiveOverlayEventArgs)
DrawCore(RectangleShape)
DxU=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
ZoomStoryCompletedCore()
PanAnimationCompletedCore()
MouseMoveInterval
  • Type:TimeSpan
Visibility
  • Type:Visibility
OverlayElement
  • Type:FrameworkElement
Attribution
TransitionEffect
Opacity
ZIndex
StoryboardForZooming
  • Type:Storyboard
StoryboardForPanning
  • Type:Storyboard
PanFrameX
  • Type:SplineDoubleKeyFrame
PanFrameY
ZoomFrameX
ZoomFrameY
qxU=
MapInfo
TranslateTransform
  • Type:TranslateTransform
ScaleTransform
  • Type:ScaleTransform
TransformGroup
  • Type:TransformGroup
MapMouseDown N/A
Event Arguments:MapMouseDownInteractiveOverlayEventArgs
MapMouseMove N/A
Event Arguments:MapMouseMoveInteractiveOverlayEventArgs
MapMouseUp N/A
Event Arguments:MapMouseUpInteractiveOverlayEventArgs
MapMouseClick N/A
Event Arguments:MapMouseClickInteractiveOverlayEventArgs
MapMouseDoubleClick N/A
Event Arguments:MapMouseDoubleClickInteractiveOverlayEventArgs
MapMouseWheel N/A
Event Arguments:MapMouseWheelInteractiveOverlayEventArgs
DrawingAttribution N/A
Event Arguments:DrawingAttributionOverlayEventArgs
DrawnAttribution N/A
Event Arguments:DrawnAttributionOverlayEventArgs
thinkgeo.mapsuite.silverlightedition.extentinteractiveoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
