thinkgeo.mapsuite.silverlightedition.mapmousewheelinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.MapMouseWheelInteractiveOverlayEventArgs
Provides data for the MapMouseWheel event.
      • ThinkGeo.MapSuite.SilverlightEdition.MapMouseWheelInteractiveOverlayEventArgs
MapMouseWheelInteractiveOverlayEventArgs()
MapMouseWheelInteractiveOverlayEventArgs(InteractionArguments)
  • interactionArguments
    • Description:This parameter specified the interaction auguments to construct the class.
This property gets the interaction auguments for the event args.
thinkgeo.mapsuite.silverlightedition.mapmousewheelinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
