thinkgeo.mapsuite.silverlightedition.interactiveresult
ThinkGeo.MapSuite.SilverlightEdition.InteractiveResult
This class specifies the InterativeResult when deal with the Interative method in InterativeOverlay.
    • ThinkGeo.MapSuite.SilverlightEdition.InteractiveResult
InteractiveResult()
InteractiveResult(InteractiveOverlayDrawType,ProcessOtherOverlaysMode)
  • interactiveOverlayDrawType
  • processOtherOverlays
DrawThisOverlay
This property gets and sets the DrawThisOverlay type to indicicate to draw this overlay or not.
This property gets and sets the DrawThisOverlay type to indicicate how to process other overlays.
NewCurrentExtent
This property gets and sets the new current extent if the interative action affect the extent.
thinkgeo.mapsuite.silverlightedition.interactiveresult.txt · Last modified: 2017/03/16 21:59 (external edit)
