thinkgeo.mapsuite.silverlightedition.mapmouseclickinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.MapMouseClickInteractiveOverlayEventArgs
Provides data for the MapMouseClick event.
      • ThinkGeo.MapSuite.SilverlightEdition.MapMouseClickInteractiveOverlayEventArgs
MapMouseClickInteractiveOverlayEventArgs()
MapMouseClickInteractiveOverlayEventArgs(InteractionArguments)
  • interactionArguments
    • Description:This parameter specified the interaction auguments to construct the class.
This property gets the interation auguments for the mouse click event args.
thinkgeo.mapsuite.silverlightedition.mapmouseclickinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
