thinkgeo.mapsuite.silverlightedition.extentchangingeventargs
ThinkGeo.MapSuite.SilverlightEdition.ExtentChangingEventArgs
This class represents the event arguments for the ExtentChanging event.
      • ThinkGeo.MapSuite.SilverlightEdition.ExtentChangingEventArgs
ExtentChangingEventArgs()
  • This is the constructor of ExtentChangingEventArgs class.
ExtentChangingEventArgs(RectangleShape,Double)
  • currentExtent
    • Description:A RectangleShape value which is current extent before the extent changing.
  • currentScale
    • Description:A value which is current scale before the extent changing.
CurrentExtent
Gets or sets current extent before the extent changes.
CurrentScale
Gets or sets current scale before the extent changes.
thinkgeo.mapsuite.silverlightedition.extentchangingeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
