thinkgeo.mapsuite.silverlightedition.overlay
ThinkGeo.MapSuite.SilverlightEdition.Overlay
Overlay()
This is constructor of Overlay class.
Overlay(String)
  • name
    • Description:A string value indicating the name of this overlay.
Refresh()
This method re-draws this overlay in current extent.
Draw(RectangleShape,OverlayDrawType)
Zooms the overlay only to the extent that you specify.
The overlay will be panned to the center and zoomlevel of the extent that you specify.
  • worldExtent
  • overlayDrawType
    • Description:The enum value indecating that the map draws features or not.
Initialize(Map)
This method initializes the overlay canvas such as width, height and z-index for first time.
  • currentMap
    • Type:Map
    • Description:Current map information.
ToWorldCoordinate(Double,Double)
This method returns a point shape in world coordinates from the specified X, Y screen coordinates.
This method converts X, Y screen coordinates to a point shape in world coodinates.
  • Description:A point shape in world coordinates.
  • screenX
    • Description:The X-value in pixels referenced to the screen origin.
  • screenY
    • Description:The Y-value in pixels referenced to the screen origin.
ToWorldCoordinate(PointShape)
This method returns a point shape in world coordinates from a ScreenPointF structure.
This method converts a screen point to a point in world coordinates.
  • screenCoordinate
    • Description:The point (in screen coordinates) to convert to world coordinates.
ToWorldCoordinate(Point)
  • screenCoordinate
    • Type:Point
ToScreenCoordinate(Double,Double)
This method returns a point shape in screen coordinates from the specified X, Y world coordinates.
This method converts X, Y world coordinates to a point in screen coordinates.
  • Description:A screen point in pixels.
  • worldX
    • Description:The X world coordinate.
  • worldY
    • Description:The Y world coordinate.
ToScreenCoordinate(PointShape)
This method returns a screen point from a point shape in world coordinates.
This method converts the coordinates of a point shape to a point in screen coordinates.
  • worldCoordinate
ToScreenCoordinate(Point)
  • worldCoordinate
    • Type:Point
    • Description:A point in world coordinates.
DrawCore(RectangleShape)
This method draws the features in the specified extent.
  • worldExtent
DxU=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
ZoomStoryCompletedCore()
This method raised when zooming animation plays completed.
PanAnimationCompletedCore()
This method raised when Panning animation plays completed.
InitializeCore()
Visibility
Gets or sets a value that indicates whether the overlay is visible on the map.
  • Type:Visibility
OverlayElement
An FrameworkElement that contains the overlay.
  • Type:FrameworkElement
Gets or sets the name of an overlay which will display in the OverlaySwitcher.
Attribution
TransitionEffect
Gets or Sets the transition effect to use when the map is panned or zoomed.
Opacity
Gets or sets the opacity level of the overlay.
The Opacity property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent(1.00), the entire overlay is made more transparent. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
ZIndex
Get or set z-index of overlay, The value is bigger, and the order is higher.
StoryboardForZooming
Gets the Storyboard object for zooming.
  • Type:Storyboard
StoryboardForPanning
Gets the Storyboard object for panning.
  • Type:Storyboard
PanFrameX
Animates from the System.Double value of the previous key frame to its own System.Windows.Media.Animation.DoubleKeyFrame.Value using splined interpolation.
  • Type:SplineDoubleKeyFrame
PanFrameY
ZoomFrameX
Gets the SplineDoubleKeyFrame for zooming.
ZoomFrameY
MapInfo
Gets or sets current map information.
TranslateTransform
Gets the TranslateTransform object of this overlay.
  • Type:TranslateTransform
ScaleTransform
Gets the ScaleTransform object of this overlay.
  • Type:ScaleTransform
TransformGroup
Gets the TranslateGroup object for panning and zooming.
  • Type:TransformGroup
DrawingAttribution N/A
Event Arguments:DrawingAttributionOverlayEventArgs
DrawnAttribution N/A
Event Arguments:DrawnAttributionOverlayEventArgs
thinkgeo.mapsuite.silverlightedition.overlay.txt · Last modified: 2017/03/16 21:59 (external edit)
