thinkgeo.mapsuite.silverlightedition.layeroverlay
ThinkGeo.MapSuite.SilverlightEdition.LayerOverlay
This class represents an Overlay that contains layers such as ShapeFileFeatureLayer, InMemoryFeatureLayer..
    • ThinkGeo.MapSuite.SilverlightEdition.Overlay
      • ThinkGeo.MapSuite.SilverlightEdition.LayerOverlay
LayerOverlay()
  • This is constructor of LayerOverlay class.
LayerOverlay(String)
  • name
    • Description:A string value indicating the name of this overlay.
Refresh()
Draw(RectangleShape,OverlayDrawType)
Initialize(Map)
  • currentMap
    • Type:Map
ToWorldCoordinate(Double,Double)
  • screenX
  • screenY
ToWorldCoordinate(PointShape)
  • screenCoordinate
ToWorldCoordinate(Point)
  • screenCoordinate
    • Type:Point
ToScreenCoordinate(Double,Double)
  • worldX
  • worldY
ToScreenCoordinate(PointShape)
ToScreenCoordinate(Point)
  • worldCoordinate
    • Type:Point
InitializeCore()
  • This method initializes the properties of the overlay canvas such as width, height and z-index for first time.
DrawCore(RectangleShape)
  • This method draws the features in the specified extent.
  • worldExtent
DxU=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
ZoomStoryCompletedCore()
PanAnimationCompletedCore()
Layers
Gets a GeoCollection that contains the layers that will draw on the image that is sent to the browser.
The Layers property holds all of the layers that are used by the Draw method. The Draw method loops through all layers to filter out features and draw with specified styles to the image that will be sent to the browser.
DrawMode.WritableBitmap is more responsive. DrawMode.Shape draws faster.
Visibility
  • Type:Visibility
OverlayElement
  • Type:FrameworkElement
Attribution
TransitionEffect
Opacity
ZIndex
StoryboardForZooming
  • Type:Storyboard
StoryboardForPanning
  • Type:Storyboard
PanFrameX
  • Type:SplineDoubleKeyFrame
PanFrameY
ZoomFrameX
ZoomFrameY
MapInfo
TranslateTransform
  • Type:TranslateTransform
ScaleTransform
  • Type:ScaleTransform
TransformGroup
  • Type:TransformGroup
DrawingAttribution N/A
Event Arguments:DrawingAttributionOverlayEventArgs
DrawnAttribution N/A
Event Arguments:DrawnAttributionOverlayEventArgs
thinkgeo.mapsuite.silverlightedition.layeroverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
