This class inherits from Overlay abstract class. This specified overlay describes the interative process with the MapControl using the Mouse or Keyboard.
KeyUp(KeyEventInteractionArguments)
MouseDown(InteractionArguments)
MouseMove(InteractionArguments)
MouseClick(InteractionArguments)
MouseDoubleClick(InteractionArguments)
MouseWheel(InteractionArguments)
Refresh(GeoCanvas,RectangleShape)
KeyDownCore(KeyEventInteractionArguments)
KeyUpCore(KeyEventInteractionArguments)
MouseDownCore(InteractionArguments)
MouseMoveCore(InteractionArguments)
MouseUpCore(InteractionArguments)
MouseClickCore(InteractionArguments)
MouseDoubleClickCore(InteractionArguments)
MouseWheelCore(InteractionArguments)
OnMapMouseDown(MapMouseDownInteractiveOverlayEventArgs)
OnMapMouseMove(MapMouseMoveInteractiveOverlayEventArgs)
OnMapMouseUp(MapMouseUpInteractiveOverlayEventArgs)
OnMapMouseClick(MapMouseClickInteractiveOverlayEventArgs)
OnMapMouseDoubleClick(MapMouseDoubleClickInteractiveOverlayEventArgs)
OnMapMouseWheel(MapMouseWheelInteractiveOverlayEventArgs)
OnMapKeyDown(MapKeyDownInteractiveOverlayEventArgs)
OnMapKeyUp(MapKeyUpInteractiveOverlayEventArgs)
OnDrawing(DrawingOverlayEventArgs)
OnDrawn(DrawnOverlayEventArgs)
RefreshCore(GeoCanvas,RectangleShape)
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
Lock
* This property gets the OverlayLock object.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay#Lock//
DrawingExceptionMode
* This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay#DrawingExceptionMode//
* Gets or sets the name of the overlay, which can be used to represent a specific overlay.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay#Name//
IsEmpty
* This property can be overridden by its base class. If it is not overridden, its default return value will be false. If this property is empty, we can skip drawing to achieve better performance.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay#IsEmpty//
MapMouseMove
* This event will be fired when the Mouse is moved on the Map.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay#OnMapMouseMove.28MapMouseMoveInteractiveOverlayEventArgs.29//Event Arguments:MapMouseMoveInteractiveOverlayEventArgs
MapMouseClick
* This event will be fired when the Mouse button is clicked (mouse up and mouse down in the same postion) on the Map.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay#OnMapMouseClick.28MapMouseClickInteractiveOverlayEventArgs.29//Event Arguments:MapMouseClickInteractiveOverlayEventArgs
MapMouseWheel
* This event will be fired when the Mouse wheel is scrolled while the cursor is over the Map.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay#OnMapMouseWheel.28MapMouseWheelInteractiveOverlayEventArgs.29//Event Arguments:MapMouseWheelInteractiveOverlayEventArgs
MapKeyUp
* This event will be fired when the key is released up when focusing on the Map.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay#OnMapKeyUp.28MapKeyUpInteractiveOverlayEventArgs.29//Event Arguments:MapKeyUpInteractiveOverlayEventArgs
Drawn
* This event will be fired after the Overlay is drawn.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay#OnDrawn.28DrawnOverlayEventArgs.29//Event Arguments:DrawnOverlayEventArgs
DrawnAttribution
* N/A
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29//Event Arguments:DrawnAttributionOverlayEventArgs
Event Arguments:RequestedDrawingOverlayEventArgs
Event Arguments:RequestingDrawingOverlayEventArgs
