thinkgeo.mapsuite.desktopedition.mapmousedowninteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs
Provides data for the MapMouseDown event.
      • ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs
MapMouseDownInteractiveOverlayEventArgs()
  • If you use this constructor, you must set the properties manually before use.
MapMouseDownInteractiveOverlayEventArgs(InteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs#MapMouseDownInteractiveOverlayEventArgs.28InteractionArguments.29
  • interactionArguments
    • Description:This parameter specified the interaction arguments to construct the class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs#MemberwiseClone.28.29
  • This property gets the interaction arguments for the event args.
thinkgeo.mapsuite.desktopedition.mapmousedowninteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
