thinkgeo.mapsuite.desktopedition.interactionarguments
ThinkGeo.MapSuite.DesktopEdition.InteractionArguments
This class encapsulates the information and simple method for interative actions.
    • ThinkGeo.MapSuite.DesktopEdition.InteractionArguments
InteractionArguments()
  • If you use this constructor, you have to set its properties manually before use.
  • Overrides the ToString API for an object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#ToString.28.29
  • Description:Returns a string to mark this instance, making it easy to read its properties.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractionArguments#MemberwiseClone.28.29
ScreenX
  • This property gets or sets the screen X position.
  • Type:Single
WorldX
  • This property gets or sets the world X position.
MouseButton
  • This property gets or sets the MouseButton used for the interative action.
SearchingTolerance
  • This property gets or sets the search tolearance for tracking and editing.
MapHeight
  • This property gets or sets the height for the Map Control.
ZoomLevelSet
  • This property gets or sets the ZoomLevelSet used in the Map Control.
MouseWheelDelta
  • This property gets or sets the mouse wheel delta used in the MouseWheel method in InterativeOverlay.
ExtendedProperties
  • This property gets the extended properties in the current status.
thinkgeo.mapsuite.desktopedition.interactionarguments.txt · Last modified: 2017/03/16 21:59 (external edit)
